- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
Kernels
- GaussDB(for MySQL) Kernel Version Release History
Common Kernel Functions
- Parallel Query
- Near Data Processing
- DDL Optimization
- Backward Index Scan
- Statement Outline
- Idle Transaction Disconnection
- LIMIT...OFFSET Pushdown
- Conversion of IN Predicates Into Subqueries
- DISTINCT Optimization for Multi-Table Joins
- Diagnosis on Large Transactions
- Enhanced Partitioned Tables
- Hot Row Update
- Multi-tenant Management and Resource Isolation
- Column Compression
User Guide
- Permissions Management
- Buying a DB Instance
- Connecting to a DB Instance
- Database Usage
- Data Migration
Instance Management
- Viewing the Overall Status of DB Instances
- Viewing Metrics
- Instance Lifecycle Management
Configuration Changes
- Changing the vCPUs or Memory of a DB Instance or Node
- Changing the Storage Space of a DB Instance
- Configuring Auto Scaling for a DB Instance
- Changing the Maintenance Window of a DB Instance
- Customizing Displayed Items of the Instance List
- Upgrading the Minor Kernel Version of a DB Instance
- Updating the OS of a DB Instance
- Data Backups
- Data Restorations
- Serverless Instances
- Read Replicas
Database Proxy (Read/Write Splitting)
- What Is Database Proxy
- How to Use a Proxy Instance to Enable Read/Write Splitting
Changing Configurations of a Proxy Instance
- Changing the Consistency Level of a Proxy Instance
- Enabling the Connection Pool for a Proxy Instance
- Enabling Transaction Splitting for a Proxy Instance
- Modifying the Routing Policy of a Proxy Instance
- Changing Read Weights of Nodes
- Modifying the Multi-statement Processing Mode of a Proxy Instance
- Enabling Automatic Association of New Nodes with a Proxy Instance
- Enabling Access Control for a Proxy Instance
- Changing the Specifications of a Proxy Instance
- Changing the Number of Nodes for a Proxy Instance
- Applying for a Private Domain Name for a Proxy Instance
- Changing the Port of a Proxy Instance
- Changing the Proxy Address of a Proxy Instance
- Modifying Parameters of a Proxy Instance
- Binding an EIP to a Proxy Instance
- Proxy Instance Lifecycle
- Proxy Instance Kernel Versions
- Using Hints for Read/Write Splitting
- DBA Assistant
- Parameter Management
- Security and Encryption
- Application Lossless and Transparent (ALT)
- HTAP Analysis (Standard Edition)
RegionlessDB Clusters
- RegionlessDB Cluster Overview
- Using a RegionlessDB Cluster for Remote Multi-Active DR
- Using a RegionlessDB Cluster for Remote DR
- Performing a Primary/Standby Switchover or Failover in a RegionlessDB Cluster
- Removing a Standby Instance from a RegionlessDB Cluster
- Deleting a RegionlessDB Cluster
- Viewing the Replication Latency and Traffic of a RegionlessDB Cluster
- Monitoring and Alarms
- Logs and Auditing
- Task Center
- Tag Management
- Quota Management
- Best Practices
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
- DB Engine Version Queries
- Database Specification Queries
Instance Management
- Creating a DB Instance
- Rebooting a DB Instance
- Deleting/Unsubscribing from a DB Instance
- Creating a Read Replica
- Deleting or Unsubscribing from a Read Replica
- Scaling up Storage of a Yearly/Monthly DB Instance
- Changing a DB Instance Name
- Resetting a Database Password
- Changing DB Instance Specifications
- Querying Dedicated Resource Pools
- Querying Dedicated Resources
- Configuring the Monitoring By Seconds Function
- Querying the Configuration of Monitoring by Seconds
- Rebooting a Node
- Upgrading the Kernel Version of a DB Instance
- Enabling or Disabling SSL
- Binding an EIP
- Unbinding an EIP
- Promoting a Read Replica to Primary
- Changing a Maintenance Window
- Changing a Security Group
- Changing a Private IP Address
- Changing a Database Port
- Changing a DB Instance Description
- Changing a Private Domain Name
- Querying the Kernel Version
- Modifying Auto Scaling Policies
- Querying Auto Scaling Policies
- Pre-Checking Resources
- Querying DB instances
- Querying Details of a DB Instance
- Querying Details of DB Instances in Batches
- Modifying a Recycling Policy
- Querying a Recycling Policy
- Querying Instances in the Recycle Bin
- Changing Node Names in Batches
- Querying Historical Records of Auto Scaling
- Setting a Policy for a Serverless DB Instance
- Changing the Failover Priority of a Read Replica
- Querying an EIP
Backup Management
- Configuring a Same-Region Backup Policy
- Creating a Manual Backup
- Querying Full Backups
- Querying an Automated Backup Policy
- Deleting a Manual Backup
- Restoring Data to the Original Instance or an Existing Instance
- Querying the Restoration Time Range
- Enabling or Disabling Encrypted Backup
- Checking Whether Encrypted Backup Is Enabled
- Querying Incremental Backups
- Configuring a Cross-Region Backup Policy
- Restoring Tables to a Specified Point in Time
- Querying Tables for Table-level Point-in-Time Recovery
Parameter Template Management
- Querying Parameter Templates
- Creating a Parameter Template
- Deleting a Parameter Template
- Obtaining Details About a Parameter Template
- Modifying Parameters in a Parameter Template
- Applying a Parameter Template
- Replicating a Parameter Template
- Comparing Parameter Templates
- Querying Instances That a Parameter Template Can Be Applied To
- Viewing Parameter Change History
- Obtaining Parameter Information of a Specified DB Instance
- Modifying Parameters of a Specified DB Instance
- Replicating the Parameter Template of a DB Instance
- Querying Application Records of a Parameter Template
- Quota Management
Database Proxy
- Creating a Proxy Instance
- Deleting a Proxy Instance
- Querying Proxy Instances
- Querying Proxy Instance Specifications
- Adding Proxy Nodes
- Deleting Proxy Nodes
- Changing Specifications of a Proxy Instance
- Assigning Read Weights
- Changing the Routing Policy of a Proxy Instance
- Enabling or Disabling Transaction Splitting of a Proxy Instance
- Enabling or Disabling Automatic Association of New Nodes with Proxy Instances
- Changing Session Consistency of a Proxy Instance
- Changing the Connection Pool Type of a Proxy Instance
- Upgrading the Kernel Version of a Proxy Instance
- Modifying the Name of a Proxy Instance
- Querying Access Control Settings of a Proxy Instance
- Querying the Minor Version of a Proxy Instance
- Querying Kernel Parameters of a Proxy Instance
- Enabling or Disabling Access Control
- Configuring Access Control Rules
- Enabling or Disabling SSL for a Proxy Instance
- Rebooting a Proxy Instance
Log Management
- Enabling or Disabling SQL Explorer
- Querying Whether SQL Explorer Is Enabled
- Querying Slow Query Logs
- Querying Error Logs
- Obtaining the Temporary Link for Downloading Full SQL
- Querying LTS Configurations of an Instance
- Deleting LTS Configurations in Batches
- Creating LTS Configurations in Batches
- Querying Whether Show Original Log Is Enabled
- Enabling or Disabling Show Original Log
- Tag Management
- Database User Management
- Database Management
- SQL Statement Concurrency Control
- Task Center
- Intelligent Diagnosis
HTAP (Standard Edition)
- Restoring a Data Synchronization Task for a StarRocks Instance
- Stopping a Data Synchronization Task for a StarRocks Instance
- Creating a StarRocks Instance
- Querying a StarRocks Instance
- Deleting a StarRocks Instance
- Rebooting a StarRocks Instance
- Rebooting a StarRocks Node
- Checking StarRocks Resources
- Querying HTAP Engine Resources
- Obtaining the Storage Type of an HTAP Instance
- Querying Specifications of an HTAP Instance
- Querying HTAP Instances
- Creating a Data Synchronization Task for a StarRocks Instance
- Deleting a Data Synchronization Task for a StarRocks Instance
- Querying Data Synchronization Tasks of a StarRocks Instance
- Checking Database Configurations for HTAP Data Synchronization
- Querying Configurations of a StarRocks Data Synchronization Task
- Querying Database Parameter Settings for StarRocks Data Synchronization
- Querying Databases of a StarRocks Instance
- Querying Database Accounts
- Creating a Database Account
- Deleting a Database Account
- Changing the Password of a Database Account
- Changing Permissions of a Database Account
HTAP (Lightweight Edition)
- Querying Node Information in Error Logs or Slow Query Logs
- Checking Database Configurations for Data Synchronization
- Checking Table Configurations for Data Synchronization
- Querying Data Synchronization Configurations
- Querying Database Parameter Settings for Data Synchronization
- Creating an Instance
- Deleting an Instance
- Querying Instance Details
- Scaling Up Storage Space of an Instance
- Rebooting an Instance
- Querying Data Synchronization Information
- Modifying Data Synchronization Configurations
- Stopping Modifying Data Synchronization Configurations
- Changing Instance Specifications
APIs (Unavailable Soon)
Instance Management
- Querying DB Instances
- Deleting a DB Instance
- Deleting a Read Replica
- Modifying DB Instance Specifications
- Backup Management
- Parameter Template Management
- Quota Management
- Database Proxy
- Log Management
- Task Information Queries
- Appendix
- SDK Reference
- Product Consulting
- Resource Freezing, Unfreezing, Release, Deletion, and Unsubscription
Database Connections
- What Should I Do If I Can't Connect to My GaussDB(for MySQL) Instance?
- What Should I Do If an ECS Can't Connect to a GaussDB(for MySQL) Instance?
- Can an External Server Access a GaussDB(for MySQL) Instance?
- What Is the Maximum Number of Connections to a GaussDB(for MySQL) Instance?
- What Do I Do If the Number of GaussDB(for MySQL) Database Connections Reaches the Upper Limit?
- Are There Any Potential Risks If There Are Too Many Connections to a GaussDB(for MySQL) Instance?
- What Should I Do If the Network Connectivity Test Fails?
- Can I Access a GaussDB(for MySQL) Instance over an Intranet Connection Across Regions?
- How Do I Check the Connections to a GaussDB(for MySQL) Instance?
- How Do I Enable Availability Detection for a Connection Pool in the Service Code?
- Client Installation
- Database Migration
- Database Permissions
Database Performance
- What Should I Do If the CPU Usage of My GaussDB(for MySQL) Instance Is High?
- How Do I Handle Slow SQL Statements Caused by Inappropriate Composite Index Settings?
- How Do I Handle a Large Number of Temporary Tables Being Generated for Long Transactions and High Memory Usage?
- What Should I Do If Locks on Long Transactions Block the Execution of Subsequent Transactions?
- How Can I Use Temporary Disk of GaussDB(for MySQL)?
- What Is the CPU Usage of a GaussDB(for MySQL) Instance with Empty Load?
Database Usage
- Why Are the Results Inconsistent After the MATCH AGAINST Statement Is Executed, Respectively, on Primary Nods and Read Replicas?
- How Do I Add Columns Using INSTANT?
- How Do I Use LOAD DATA to Import Local Data?
- How Do I Write Data to or Create Indexes for an Ultra-large Table?
- What Are the Risks of Deleting an Index from an Ultra-large Table?
- Backups
Database Parameter Modification
- How Do I Change the Time Zone of a GaussDB(for MySQL) Instance?
- How Do I Configure a Password Expiration Policy for GaussDB(for MySQL) Instances?
- How Do I Ensure that the Database Character Set of a GaussDB(for MySQL) Instance Is Correct?
- How Do I Use the utf8mb4 Character Set to Store Emojis in a GaussDB(for MySQL) Instance?
- How Do I Set Case Sensitivity for GaussDB(for MySQL) Table Names?
- Can I Use SQL Commands to Modify Global Parameters of My GaussDB(for MySQL) Instance?
- Network Security
- Log Management
- Version Upgrade
Troubleshooting
Backup and Restoration Issues
- Insufficient Permissions During Data Export Using mysqldump
- How Do I use mysqlbinlog to Obtain Binlog Files?
- Canal Fails to Parse Binlogs
- Precautions for Exporting Large Tables Through mysqldump
- Commands for Exporting Data Through mysqldump
- System Inaccessible After Field Addition to a Database Table
- SQL Statements Such as SET @@SESSION.SQL_LOG_BIN Displayed After You Run mysqldump
- Insufficient Permissions Reported for Canal
Connection Issues
- Login Failed After ssl_type of root Is Changed to ANY
- Failed to Connect to a DB Instance Using SSL
- Description of Each IP Address
- SSL Connection Failed Due to Inconsistent TLS Versions
- Error Message "connection established slowly"
- "Access denied" Displayed During Database Connection
- Failed to Connect to a Database Using mariadb-connector in SSL Mode
- Failed to Connect to a Database as User root
- Client Automatically Disconnected from a DB Instance
- Disconnection Occurs Every 45 Days Due to the istio-citadel Certificate Mechanism
SQL Issues
- Invalid TIMESTAMP Default Value during Table Creation
- Failed to Change the VARCHAR Length Due to the Index Length Limit
- Slow SQL Queries After a Large Amount of Data Is Deleted from a Large Table
- Error 1366 Reported When Data Containing Emojis Is Updated
- Slow Stored Procedure Execution Due to Inconsistent Collations
- ERROR [1412] Reported for a DB Instance
- Failed to Delete a Table with a Foreign Key
- Incorrect GROUP_CONCAT Results
- Error Message "Too many keys specified" Displayed When a Secondary Index Is Created
- DISTINCT and GROUP BY Optimization
- Equivalent Comparison Failures with Floating-Point Numbers
- A Large Number of SELECT Requests Routed to The Primary Instance After Database Proxy Is Enabled
- Tablespace Bloat
- ERROR 1396 Reported When a User Is Created
- Error Message Reported When alter table xxx discard/import tablespace Is Executed
- Native Error 1461 Reported by a DB Instance
- "Row size too large" Reported When a Table Failed to Be Created
- Duplicate Data Exists After ORDER BY LIMIT Is Executed
- Parameter-related Issues
Performance Issues
- High CPU Usage
- Out of Memory (OOM) Errors
- Tablespace Bloat
- Read Replica Uses Far More Storage Than the Primary Instance
- Slow SQL Execution Due to Hot and Cold Data Problems
- Full Storage Caused by Complex Queries
- Slow Response Due to Deadlocks
- CPU Usage Increase
- CPU Resource Exhaustion Caused by Too Many Concurrent Slow Queries
Basic Issues
- How Do I View Used Storage of My GaussDB(for MySQL) Instance?
- Renaming Databases and Tables
- Character Set and Collation Settings
- Auto-Increment Field Value Jump
- Starting Value and Increment of AUTO_INCREMENT
- Changing the AUTO_INCREMENT Value of a Table
- Failed to Insert Data Because Values for the Auto-increment Primary Key Field Reach the Upper Limit
- Auto-increment Field Values
- AUTO_INCREMENT Not Displayed in the Table Structure
- Impact of Creating an Empty Username
- No Scanned Rows Recorded in Slow Query Logs
- "handle_sync_msg_from_slave my_net_read error:-1" Displayed on the Error Logs Tab Page
- Videos
Viewing Metrics
The Metrics page allows you to monitor GaussDB(for MySQL) instances.
- You can view the real-time performance metrics and trends of all instances in your account. This allows you to quickly identify and address any abnormal instances.
- You can also view the historical performance metrics.
Viewing Real-Time Metrics
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- In the navigation pane, choose Metrics.
- View the real-time performance metrics of a created GaussDB(for MySQL) instance under the current account.
Figure 1 Viewing real-time metrics
Table 1 Parameter description Parameter
Node Name/ID
Only monitoring data for the nodes of a created GaussDB(for MySQL) instance is displayed.
Status
The value can be:
- Normal: Real-time monitoring data is displayed.
The monitoring data and charts are available for a new instance after the instance runs for about 10 minutes.
- Abnormal: There is no monitoring data. The default values for all metrics are 0. The monitoring data is available only after the instance becomes normal.
- Stopped: There is no monitoring data. The default values for all metrics are 0. The monitoring data is available only after the instance is started.
Node Type
The value can be:
- Primary
- Replica
Availability Zone
AZ where a node is located
Private IP Address
Private IP address of a node
Failover Priority
Failover priority of a node
Metrics
For details about metric description and handling suggestions for abnormal metrics, see Table 2. The following metrics are available:
- CPU Usage
- Memory Usage
- TPS
- QPS
Table 2 Monitoring items Item
Handling Suggestion
Reference
CPU Usage
CPU usage of the monitored object
- Evaluate the SQL execution plan and add indexes to avoid full table scanning.
- Upgrade vCPUs for compute-intensive workloads.
Memory Usage
Memory usage of the monitored object
- Upgrade instance specifications.
- Optimize SQL statements to reduce the use of temporary tables.
- Reconnect sessions at a specific interval to release memory of the sessions.
TPS
Execution times of submitted and rollback transactions per second
QPS
Query times of SQL statements (including stored procedures) per second
Viewing Historical Metrics
- You can view the metrics of up to six nodes at a time.
- You can view the performance metrics in the last 1 hour, last 3 hours, last 12 hours, last 24 hours, or last 7 days. You can also configure a time period.
- You can move the cursor to a point in time of a chart to view the performance metric at that point in time.
Figure 3 Viewing a performance metric at a point in time
