- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
Kernels
- GaussDB(for MySQL) Kernel Version Release History
Common Kernel Functions
- Parallel Query
- Near Data Processing
- DDL Optimization
- Backward Index Scan
- Statement Outline
- Idle Transaction Disconnection
- LIMIT...OFFSET Pushdown
- Conversion of IN Predicates Into Subqueries
- DISTINCT Optimization for Multi-Table Joins
- Diagnosis on Large Transactions
- Enhanced Partitioned Tables
- Hot Row Update
- Multi-tenant Management and Resource Isolation
- Column Compression
User Guide
- Permissions Management
- Buying a DB Instance
- Connecting to a DB Instance
- Database Usage
- Data Migration
Instance Management
- Viewing the Overall Status of DB Instances
- Viewing Metrics
- Instance Lifecycle Management
Configuration Changes
- Changing the vCPUs or Memory of a DB Instance or Node
- Changing the Storage Space of a DB Instance
- Configuring Auto Scaling for a DB Instance
- Changing the Maintenance Window of a DB Instance
- Customizing Displayed Items of the Instance List
- Upgrading the Minor Kernel Version of a DB Instance
- Updating the OS of a DB Instance
- Data Backups
- Data Restorations
- Serverless Instances
- Read Replicas
Database Proxy (Read/Write Splitting)
- What Is Database Proxy
- How to Use a Proxy Instance to Enable Read/Write Splitting
Changing Configurations of a Proxy Instance
- Changing the Consistency Level of a Proxy Instance
- Enabling the Connection Pool for a Proxy Instance
- Enabling Transaction Splitting for a Proxy Instance
- Modifying the Routing Policy of a Proxy Instance
- Changing Read Weights of Nodes
- Modifying the Multi-statement Processing Mode of a Proxy Instance
- Enabling Automatic Association of New Nodes with a Proxy Instance
- Enabling Access Control for a Proxy Instance
- Changing the Specifications of a Proxy Instance
- Changing the Number of Nodes for a Proxy Instance
- Applying for a Private Domain Name for a Proxy Instance
- Changing the Port of a Proxy Instance
- Changing the Proxy Address of a Proxy Instance
- Modifying Parameters of a Proxy Instance
- Binding an EIP to a Proxy Instance
- Proxy Instance Lifecycle
- Proxy Instance Kernel Versions
- Using Hints for Read/Write Splitting
- DBA Assistant
- Parameter Management
- Security and Encryption
- Application Lossless and Transparent (ALT)
- HTAP Analysis (Standard Edition)
RegionlessDB Clusters
- RegionlessDB Cluster Overview
- Using a RegionlessDB Cluster for Remote Multi-Active DR
- Using a RegionlessDB Cluster for Remote DR
- Performing a Primary/Standby Switchover or Failover in a RegionlessDB Cluster
- Removing a Standby Instance from a RegionlessDB Cluster
- Deleting a RegionlessDB Cluster
- Viewing the Replication Latency and Traffic of a RegionlessDB Cluster
- Monitoring and Alarms
- Logs and Auditing
- Task Center
- Tag Management
- Quota Management
- Best Practices
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
- DB Engine Version Queries
- Database Specification Queries
Instance Management
- Creating a DB Instance
- Rebooting a DB Instance
- Deleting/Unsubscribing from a DB Instance
- Creating a Read Replica
- Deleting or Unsubscribing from a Read Replica
- Scaling up Storage of a Yearly/Monthly DB Instance
- Changing a DB Instance Name
- Resetting a Database Password
- Changing DB Instance Specifications
- Querying Dedicated Resource Pools
- Querying Dedicated Resources
- Configuring the Monitoring By Seconds Function
- Querying the Configuration of Monitoring by Seconds
- Rebooting a Node
- Upgrading the Kernel Version of a DB Instance
- Enabling or Disabling SSL
- Binding an EIP
- Unbinding an EIP
- Promoting a Read Replica to Primary
- Changing a Maintenance Window
- Changing a Security Group
- Changing a Private IP Address
- Changing a Database Port
- Changing a DB Instance Description
- Changing a Private Domain Name
- Querying the Kernel Version
- Modifying Auto Scaling Policies
- Querying Auto Scaling Policies
- Pre-Checking Resources
- Querying DB instances
- Querying Details of a DB Instance
- Querying Details of DB Instances in Batches
- Modifying a Recycling Policy
- Querying a Recycling Policy
- Querying Instances in the Recycle Bin
- Changing Node Names in Batches
- Querying Historical Records of Auto Scaling
- Setting a Policy for a Serverless DB Instance
- Changing the Failover Priority of a Read Replica
- Querying an EIP
Backup Management
- Configuring a Same-Region Backup Policy
- Creating a Manual Backup
- Querying Full Backups
- Querying an Automated Backup Policy
- Deleting a Manual Backup
- Restoring Data to the Original Instance or an Existing Instance
- Querying the Restoration Time Range
- Enabling or Disabling Encrypted Backup
- Checking Whether Encrypted Backup Is Enabled
- Querying Incremental Backups
- Configuring a Cross-Region Backup Policy
- Restoring Tables to a Specified Point in Time
- Querying Tables for Table-level Point-in-Time Recovery
Parameter Template Management
- Querying Parameter Templates
- Creating a Parameter Template
- Deleting a Parameter Template
- Obtaining Details About a Parameter Template
- Modifying Parameters in a Parameter Template
- Applying a Parameter Template
- Replicating a Parameter Template
- Comparing Parameter Templates
- Querying Instances That a Parameter Template Can Be Applied To
- Viewing Parameter Change History
- Obtaining Parameter Information of a Specified DB Instance
- Modifying Parameters of a Specified DB Instance
- Replicating the Parameter Template of a DB Instance
- Querying Application Records of a Parameter Template
- Quota Management
Database Proxy
- Creating a Proxy Instance
- Deleting a Proxy Instance
- Querying Proxy Instances
- Querying Proxy Instance Specifications
- Adding Proxy Nodes
- Deleting Proxy Nodes
- Changing Specifications of a Proxy Instance
- Assigning Read Weights
- Changing the Routing Policy of a Proxy Instance
- Enabling or Disabling Transaction Splitting of a Proxy Instance
- Enabling or Disabling Automatic Association of New Nodes with Proxy Instances
- Changing Session Consistency of a Proxy Instance
- Changing the Connection Pool Type of a Proxy Instance
- Upgrading the Kernel Version of a Proxy Instance
- Modifying the Name of a Proxy Instance
- Querying Access Control Settings of a Proxy Instance
- Querying the Minor Version of a Proxy Instance
- Querying Kernel Parameters of a Proxy Instance
- Enabling or Disabling Access Control
- Configuring Access Control Rules
- Enabling or Disabling SSL for a Proxy Instance
- Rebooting a Proxy Instance
Log Management
- Enabling or Disabling SQL Explorer
- Querying Whether SQL Explorer Is Enabled
- Querying Slow Query Logs
- Querying Error Logs
- Obtaining the Temporary Link for Downloading Full SQL
- Querying LTS Configurations of an Instance
- Deleting LTS Configurations in Batches
- Creating LTS Configurations in Batches
- Querying Whether Show Original Log Is Enabled
- Enabling or Disabling Show Original Log
- Tag Management
- Database User Management
- Database Management
- SQL Statement Concurrency Control
- Task Center
- Intelligent Diagnosis
HTAP (Standard Edition)
- Restoring a Data Synchronization Task for a StarRocks Instance
- Stopping a Data Synchronization Task for a StarRocks Instance
- Creating a StarRocks Instance
- Querying a StarRocks Instance
- Deleting a StarRocks Instance
- Rebooting a StarRocks Instance
- Rebooting a StarRocks Node
- Checking StarRocks Resources
- Querying HTAP Engine Resources
- Obtaining the Storage Type of an HTAP Instance
- Querying Specifications of an HTAP Instance
- Querying HTAP Instances
- Creating a Data Synchronization Task for a StarRocks Instance
- Deleting a Data Synchronization Task for a StarRocks Instance
- Querying Data Synchronization Tasks of a StarRocks Instance
- Checking Database Configurations for HTAP Data Synchronization
- Querying Configurations of a StarRocks Data Synchronization Task
- Querying Database Parameter Settings for StarRocks Data Synchronization
- Querying Databases of a StarRocks Instance
- Querying Database Accounts
- Creating a Database Account
- Deleting a Database Account
- Changing the Password of a Database Account
- Changing Permissions of a Database Account
HTAP (Lightweight Edition)
- Querying Node Information in Error Logs or Slow Query Logs
- Checking Database Configurations for Data Synchronization
- Checking Table Configurations for Data Synchronization
- Querying Data Synchronization Configurations
- Querying Database Parameter Settings for Data Synchronization
- Creating an Instance
- Deleting an Instance
- Querying Instance Details
- Scaling Up Storage Space of an Instance
- Rebooting an Instance
- Querying Data Synchronization Information
- Modifying Data Synchronization Configurations
- Stopping Modifying Data Synchronization Configurations
- Changing Instance Specifications
APIs (Unavailable Soon)
Instance Management
- Querying DB Instances
- Deleting a DB Instance
- Deleting a Read Replica
- Modifying DB Instance Specifications
- Backup Management
- Parameter Template Management
- Quota Management
- Database Proxy
- Log Management
- Task Information Queries
- Appendix
- SDK Reference
- Product Consulting
- Resource Freezing, Unfreezing, Release, Deletion, and Unsubscription
Database Connections
- What Should I Do If I Can't Connect to My GaussDB(for MySQL) Instance?
- What Should I Do If an ECS Can't Connect to a GaussDB(for MySQL) Instance?
- Can an External Server Access a GaussDB(for MySQL) Instance?
- What Is the Maximum Number of Connections to a GaussDB(for MySQL) Instance?
- What Do I Do If the Number of GaussDB(for MySQL) Database Connections Reaches the Upper Limit?
- Are There Any Potential Risks If There Are Too Many Connections to a GaussDB(for MySQL) Instance?
- What Should I Do If the Network Connectivity Test Fails?
- Can I Access a GaussDB(for MySQL) Instance over an Intranet Connection Across Regions?
- How Do I Check the Connections to a GaussDB(for MySQL) Instance?
- How Do I Enable Availability Detection for a Connection Pool in the Service Code?
- Client Installation
- Database Migration
- Database Permissions
Database Performance
- What Should I Do If the CPU Usage of My GaussDB(for MySQL) Instance Is High?
- How Do I Handle Slow SQL Statements Caused by Inappropriate Composite Index Settings?
- How Do I Handle a Large Number of Temporary Tables Being Generated for Long Transactions and High Memory Usage?
- What Should I Do If Locks on Long Transactions Block the Execution of Subsequent Transactions?
- How Can I Use Temporary Disk of GaussDB(for MySQL)?
- What Is the CPU Usage of a GaussDB(for MySQL) Instance with Empty Load?
Database Usage
- Why Are the Results Inconsistent After the MATCH AGAINST Statement Is Executed, Respectively, on Primary Nods and Read Replicas?
- How Do I Add Columns Using INSTANT?
- How Do I Use LOAD DATA to Import Local Data?
- How Do I Write Data to or Create Indexes for an Ultra-large Table?
- What Are the Risks of Deleting an Index from an Ultra-large Table?
- Backups
Database Parameter Modification
- How Do I Change the Time Zone of a GaussDB(for MySQL) Instance?
- How Do I Configure a Password Expiration Policy for GaussDB(for MySQL) Instances?
- How Do I Ensure that the Database Character Set of a GaussDB(for MySQL) Instance Is Correct?
- How Do I Use the utf8mb4 Character Set to Store Emojis in a GaussDB(for MySQL) Instance?
- How Do I Set Case Sensitivity for GaussDB(for MySQL) Table Names?
- Can I Use SQL Commands to Modify Global Parameters of My GaussDB(for MySQL) Instance?
- Network Security
- Log Management
- Version Upgrade
Troubleshooting
Backup and Restoration Issues
- Insufficient Permissions During Data Export Using mysqldump
- How Do I use mysqlbinlog to Obtain Binlog Files?
- Canal Fails to Parse Binlogs
- Precautions for Exporting Large Tables Through mysqldump
- Commands for Exporting Data Through mysqldump
- System Inaccessible After Field Addition to a Database Table
- SQL Statements Such as SET @@SESSION.SQL_LOG_BIN Displayed After You Run mysqldump
- Insufficient Permissions Reported for Canal
Connection Issues
- Login Failed After ssl_type of root Is Changed to ANY
- Failed to Connect to a DB Instance Using SSL
- Description of Each IP Address
- SSL Connection Failed Due to Inconsistent TLS Versions
- Error Message "connection established slowly"
- "Access denied" Displayed During Database Connection
- Failed to Connect to a Database Using mariadb-connector in SSL Mode
- Failed to Connect to a Database as User root
- Client Automatically Disconnected from a DB Instance
- Disconnection Occurs Every 45 Days Due to the istio-citadel Certificate Mechanism
SQL Issues
- Invalid TIMESTAMP Default Value during Table Creation
- Failed to Change the VARCHAR Length Due to the Index Length Limit
- Slow SQL Queries After a Large Amount of Data Is Deleted from a Large Table
- Error 1366 Reported When Data Containing Emojis Is Updated
- Slow Stored Procedure Execution Due to Inconsistent Collations
- ERROR [1412] Reported for a DB Instance
- Failed to Delete a Table with a Foreign Key
- Incorrect GROUP_CONCAT Results
- Error Message "Too many keys specified" Displayed When a Secondary Index Is Created
- DISTINCT and GROUP BY Optimization
- Equivalent Comparison Failures with Floating-Point Numbers
- A Large Number of SELECT Requests Routed to The Primary Instance After Database Proxy Is Enabled
- Tablespace Bloat
- ERROR 1396 Reported When a User Is Created
- Error Message Reported When alter table xxx discard/import tablespace Is Executed
- Native Error 1461 Reported by a DB Instance
- "Row size too large" Reported When a Table Failed to Be Created
- Duplicate Data Exists After ORDER BY LIMIT Is Executed
- Parameter-related Issues
Performance Issues
- High CPU Usage
- Out of Memory (OOM) Errors
- Tablespace Bloat
- Read Replica Uses Far More Storage Than the Primary Instance
- Slow SQL Execution Due to Hot and Cold Data Problems
- Full Storage Caused by Complex Queries
- Slow Response Due to Deadlocks
- CPU Usage Increase
- CPU Resource Exhaustion Caused by Too Many Concurrent Slow Queries
Basic Issues
- How Do I View Used Storage of My GaussDB(for MySQL) Instance?
- Renaming Databases and Tables
- Character Set and Collation Settings
- Auto-Increment Field Value Jump
- Starting Value and Increment of AUTO_INCREMENT
- Changing the AUTO_INCREMENT Value of a Table
- Failed to Insert Data Because Values for the Auto-increment Primary Key Field Reach the Upper Limit
- Auto-increment Field Values
- AUTO_INCREMENT Not Displayed in the Table Structure
- Impact of Creating an Empty Username
- No Scanned Rows Recorded in Slow Query Logs
- "handle_sync_msg_from_slave my_net_read error:-1" Displayed on the Error Logs Tab Page
- Videos
Show all
If there is a region-level fault on the primary instance, workloads can be switched to a standby instance for remote DR.
As shown in Figure 1, a RegionlessDB cluster contains a primary instance deployed across two AZs and a standby instance deployed in a single AZ. If the primary AZ of the primary instance is faulty, workloads are preferentially switched to the standby AZ. If both the primary and standby AZs of the primary instance are faulty, workloads are switched to the standby instance.
For details, see Constraints.
Step 1: Create a RegionlessDB Cluster
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- On the RegionlessDB page, click Create RegionlessDB in the upper right corner.
Figure 2 Creating a RegionlessDB cluster
- In the Create RegionlessDB dialog box, configure RegionlessDB Name, Primary Instance Region, and Primary Instance.
Figure 3 Configuring the RegionlessDB cluster information
Table 1 Parameter description Parameter
RegionlessDB Name
The name must start with a letter and consist of 4 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), and underscores (_) are allowed.
Select a region where the primary instance is located.
Primary Instance
Select an existing DB instance as the primary instance of the RegionlessDB cluster.
- Click OK.
- After the primary instance is created, view and manage it.
During the creation process, the instance status is Creating. To view the detailed progress and result of the creation, go to the Task Center page. After the status of the primary instance is Available, you can use the instance.
Step 2: Add a Standby Instance
- On the RegionlessDB page, locate the RegionlessDB cluster.
- Click Add Standby Instance in the Operation column.
Figure 4 Adding a standby instance
- On the displayed page, configure related parameters.
Table 2 Basic information Parameter
Region
Region where the standby instance is deployed.
NOTICE:Products in different regions cannot communicate with each other through a private network. After a DB instance is purchased, the region cannot be changed.
Creation Method
Create new
DB Instance Name
The name must start with a letter and consist of 4 to 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
DB Engine
GaussDB(for MySQL)
DB Engine Version
MySQL 8.0
Kernel Version
Kernel version of the standby instance. The kernel version must be 2.0.46.231000 or later.
For details about the updates in each minor kernel version, see Kernel Version Release History.
To configure the kernel version, contact customer service.
DB Instance Type
Only Primary/Standby can be selected. There are 2 to 10 read replicas in a primary/standby instance in the RegionlessDB cluster.
Storage Type
Shared
AZ Type
An AZ is a physical region where resources have their own independent power supply and networks. AZs are physically isolated but interconnected through an internal network. Some regions support both single-AZ and multi-AZ deployment and some only support single-AZ deployment.
- Single AZ: The primary node and read replicas are deployed in the same AZ.
- Multi-AZ: The primary node and read replicas are deployed in different AZs to ensure high reliability.
Time Zone
You need to select a time zone for your instance based on the region hosting your instance. The time zone is selected during instance creation and cannot be changed after the instance is created.
For details about the specifications supported by GaussDB(for MySQL), see Instance Specifications.
GaussDB(for MySQL) is a cloud-native database that uses the shared storage. To ensure service stability in high read/write pressure, the system controls the read/write peaks of DB instances based on instance specifications. For details about how to select specifications, see Performance White Paper.
CPU Architecture
The CPU architecture can be x86 or Kunpeng. Under a CPU architecture, you need to select vCPUs and memory of the instance.
Nodes
All nodes of the standby instance are read replicas. You can apply for a maximum of 10 read replicas at a time for a pay-per-use instance.
After an instance is created, you can add read replicas as required. Up to 15 read replicas can be created for a standby instance in a cluster.
Storage will be scaled up dynamically based on the amount of data that needs to be stored, and is billed hourly on a pay-per-use basis.
VPC
- A dedicated virtual network in which your GaussDB(for MySQL) instance is located. It isolates networks for different workloads. You can select an existing VPC or create a VPC. For details about how to create a VPC, see Creating a VPC.
If no VPC is available, GaussDB(for MySQL) allocates a VPC to you by default.
NOTICE:- Ensure that the VPC selected for the standby instance is connected to the VPC selected for the primary instance through a VPN.
- After a GaussDB(for MySQL) instance is created, the VPC cannot be changed.
- A subnet provides dedicated network resources that are logically isolated from other networks for network security.
A private IP address is automatically assigned when you create a DB instance. You can also enter an idle private IP address in the subnet CIDR block.
Security Group
It can enhance security by controlling access to GaussDB(for MySQL) from other services. When you select a security group, you must ensure that it allows the client to access instances.
If no security group is available or has been created, GaussDB(for MySQL) allocates a security group to you by default.
- To ensure subsequent database connection and access, you need to allow all IP addresses to access your DB instance through port 3306 and over ICMP.
- Configure private network security group rules to ensure that the primary and standby instances in a cluster can communicate with each other.
Parameter Template
Contains engine configuration values that can be applied to one or more instances. You can modify the instance parameters as required after the instance is created.
NOTICE:If you use a custom parameter template when creating a DB instance, the following specification-related parameters in the custom template are not applied. Instead, the default values are used.
innodb_buffer_pool_size
innodb_log_buffer_size
max_connections
innodb_buffer_pool_instances
innodb_page_cleaners
innodb_parallel_read_threads
innodb_read_io_threads
innodb_write_io_threads
threadpool_size
After a DB instance is created, you can adjust its parameters as needed. For details, see Modifying Parameters in a Parameter Template.
Enterprise Project
Only available for enterprise users. If you want to use this function, contact customer service.
An enterprise project provides a way to manage cloud resources and enterprise members on a project-by-project basis.
You can select an enterprise project from the drop-down list. The default project is default.
Tag
This parameter is optional. Adding tags helps you better identify and manage your DB instances. Each DB instance can have up to 20 tags.
After a DB instance is created, you can view its tag details on the Tags tab. For details, see Managing Tags.
The instance password and table name case sensitivity are the same as those of the primary instance. You do not need to set them separately.
- Click Next.
- Confirm the information and click Submit.
- Go to the Instances page to view and manage the instance.
During the creation process, the instance status is Creating. To view the detailed progress and result of the creation, go to the Task Center page. After the status of the instance is Available, you can use the instance.
If there is a large amount of data in the primary instance, it may take a long time to complete a full backup during standby instance creation.
Step 3: Connect to a Standby Instance for Workload Management
Select the nearest standby instance to access the database based on the workload access area.
For example, use a standby instance to access the database and query data.
mysql> select * from mydatabase.orders; +----------+---------------+------------+ | order_id | customer_name | order_date | +----------+---------------+------------+ | 1 | UserA | 2023-12-18 | | 2 | UserB | 2023-12-17 | | 3 | UserC | 2023-12-16 | +----------+---------------+------------+
