Help Center/
GaussDB(for MySQL)/
User Guide/
Database Proxy (Read/Write Splitting)/
Changing Configurations of a Proxy Instance/
Changing the Specifications of a Proxy Instance
Updated on 2024-09-24 GMT+08:00
If the proxy specifications cannot meet your workload requirements, you can manually upgrade them.
- The proxy instance specifications can be changed only when your GaussDB(for MySQL) instance, primary node, and read replicas are normal.
- A proxy instance cannot be deleted when its CPU and memory specifications are being changed.
- Click in the upper left corner and select a region and project.
- Click in the upper left corner of the page, choose .
- On the Instances page, click the target DB instance name to go to the Basic Information page.
- In the navigation pane on the left, choose Database Proxy.
- On the Database Proxy page, locate the desired proxy instance and choose More > Change Specifications in the Operation column.
Figure 1 Changing proxy instance specifications (1)
You can also click the proxy instance name. In the Proxy Instance Information area, click Change next to the Specifications field.
Figure 2 Changing proxy instance specifications (2)
- In the displayed dialog box, select new specifications and click OK. You can reduce or expand the specifications as required.
Figure 3 Changing proxy instance specifications (3)
- View the new specifications on the Database Proxy page.
