On this page
Show all
Help Center/ TaurusDB/ User Guide/ Database Proxy (Read/Write Splitting)/ Using Hints for Read/Write Splitting
Updated on 2024-11-06 GMT+08:00
In addition to configuring weights of nodes for read/write splitting, you can use hints in SQL statements to route read and write requests to a primary node or read replica.
Precautions
  • Hints are only used as routing suggestions. In non-read-only SQL and non-transaction scenarios, SQL statements cannot be routed to read replicas.
  • If you want to connect to a DB instance using the MySQL CLI and hints, add the -c option.
Usage
You can add the following hints at the beginning of an SQL statement as needed.
/*FORCE_MASTER*/: The SQL statement is executed on the primary node.
/*FORCE_SLAVE*/: The SQL statement is executed on read replicas.
For example, if you run select * from table1, the SQL statement will be executed on a read replica by default. If you change it to /*FORCE_MASTER*/ select * from table1, the SQL statement will be executed on the primary node.
CAUTION:
/*FORCE_MASTER*/ only works for read/write addresses. Even if you use it for a read-only address, the SQL statement will not be executed on the primary node.
