On this page
Show all
Overview
Updated on 2024-11-06 GMT+08:00
You can connect to a GaussDB(for MySQL) instance through Data Admin Service (DAS), a private network, a public network, or JDBC.
Table 1 Connection methods
Connect Through
Connection Address
Comments
DAS
Not required
DAS enables you to manage GaussDB(for MySQL) instances from a web-based console, simplifying database management and improving efficiency. By default, you have the remote login permission. It is recommended that you use DAS to connect to the instances because this connection method is more secure and convenient than other methods.
  • Easy to use, secure, advanced, and intelligent
  • Recommended
Private network
Private IP address
A private IP address is provided by default.
When your applications are deployed on an ECS that is in the same region and VPC as your GaussDB(for MySQL) instance, you are advised to connect the ECS to the instance over a private IP address.
  • Secure and excellent performance
  • Recommended
Public network
EIP
If you cannot access your GaussDB(for MySQL) instance over a private IP address, bind an EIP to the instance and connect it to the ECS (or a public network host) over the EIP.
  • A relatively lower level of security compared with other connection methods.
  • To achieve a higher data transmission rate and security level, you are advised to migrate your applications to an ECS that is in the same VPC as your GaussDB(for MySQL) instance and use a private IP address to access the instance.
JDBC
Private IP address or EIP
JDBC is used to access GaussDB(for MySQL) instances.
  • VPC: indicates the Virtual Private Cloud.
  • ECS: indicates the Elastic Cloud Server.
  • You can log in to a DB instance using DAS or other database clients.
  • If an ECS is in the same VPC as your GaussDB(for MySQL) instance, you do not need to apply for an EIP.
  • If you are using GaussDB(for MySQL) for the first time, see Constraints.
