Kernel Version Release History
Released On |
Version |
Description |
2024-05-07 |
2.24.03.000 |
Added the feature for assigning requests to row and column store nodes. |
2024-01-15 |
2.23.12.000 |
2024-01-04 |
2.23.09.002 |
Fixed the logic for proxy instances to retry service SQL statements after the database is faulty. |
2023-11-13 |
2.23.09.001 |
Fixed the issue that an error is occasionally reported during execution of the prepared SELECT FOR UPDATE statement. |
2023-10-20 |
2.23.09.000 |
New features:
2023-07-31 |
2.23.06.001 |
Fixed the increased backend database connections caused by enabling session connection pool. |
2023-07-06 |
2.23.06.000 |
2023-06-11 |
2.23.02.007 |
Fixed issues:
2023-04-27 |
2.23.02.000 |
Optimized the proxy instance performance. |
2022-12-05 |
2.22.11.000 |
Added multi-statement processing modes. Optimized the error messages reported during SQL statement execution in some scenarios. |
2022-09-06 |
2.22.07.000 |
New features:
Optimized the logic for setting session-level transaction isolation levels of proxy instances. By default, the transaction isolation levels are synchronized with those of the database. |
2022-06-15 |
2.7.5.0 |
Added Application Lossless and Transparent (ALT). |
2022-05-06 |
2.7.4.0 |
New features:
Optimized the way how metrics of read-only proxy instances are collected by Cloud Eye. |
2022-04-01 |
2.3.9.8 |
Added batch execution of prepared statements. |
2022-02-09 |
2.3.9.7 |
New features:
Optimized the execution logic of prepared statements to improve performance. |
2021-04-23 |
2.3.9.0 |
Add proxy instance performance metrics Front-End Connections Created per Second, Transaction Queries per Second, and Multi-Statement Queries per Second. Fixed issues:
2021-01-14 |
2.3.8.0 |
Added the feature for obtaining client IP addresses through proxy instances. Fixed issues:
2020-10-14 |
2.3.6.0 |
Fixed issues:
2020-08-14 |
2.3.1.0 |
New features:
