Restoring a DB Instance from a Cross-region Backup
GaussDB(for MySQL) can store backups in a different region from your DB instance. If your DB instance is faulty, you can use a backup to restore data to a new DB instance in the region where the backup is stored.
A cross-region backup has been completed. For details, see Configuring a Cross-Region Backup Policy.
- Click in the upper left corner and select a region and project.
- Click in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- In the upper left corner of the page, select the region where the backup is located.
- In the navigation pane, choose Backups. On the displayed page, click the Cross-Region Backups tab.
- Locate the target DB instance and click View Cross-Region Backup in the Operation column.
Figure 1 Cross-region backups
- On the displayed page, select the backup to be restored.
Currently, full and incremental backups can be restored to new DB instances.
Restoring a full backup- Locate the target backup and click Restore in the Operation column.
Figure 2 Restoring a full backup
- In the displayed dialog box, confirm instance details and click OK.
Figure 3 Restoring a full backup to a new DB instance
- On the displayed page, set the parameters of the new DB instance and click Next.
- The region, DB engine, and DB engine version are the same as those of the original DB instance and cannot be changed.
- The default database port is 3306.
- Other settings are the same as those of the original DB instance by default and can be modified. For details, see Buying a DB Instance.
Restoring an incremental backup
- Click Restore to Point in Time.
Figure 4 Restoring an incremental backup
- Select the date and time range, and select or enter a time point within the time range.
Figure 5 Restoring an incremental backup to a point in time
- Click OK.
