On this page
Connecting to a Standard HTAP Instance Through JDBC
Updated on 2024-11-06 GMT+08:00
You can connect to a standard HTAP instance through JDBC.
Precautions
Currently, HTAP instances only support the UTF-8 character set.
  • You are familiar with:
    • Computer basics
    • Java
    • JDBC knowledge
  • You have downloaded the official JDBC driver for MySQL or MirrorDB.
  • You have created a standard HTAP instance.
  • The following dependency has been added to the pom.xml file.
    <dependency>
        <groupId>mysql</groupId>
        <artifactId>mysql-connector-java</artifactId>
        <version>5.1.47</version>
    </dependency>
  • You can use the following command to connect to an HTAP instance through JDBC:
    jdbc:mysql://<instance_ip>:<instance_port>/<database_name>
    <instance_ip>
    IP address of the FE node in the HTAP instance. If a proxy is installed, use the IP address of the proxy.
    <instance_port>
    HTAP instance port. The default value is 3306.
    <database_name>
    Database name used for connecting to the instance.
Sample Code
Code example (Java code for connecting to an HTAP database):
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.Statement;
import java.sql.SQLException;
public class JDBCTest {
    static final String IP = "*.*.*.*"; //IP address of the instance
    static final String USER = "***"; //Username
    static final String PASS = "***"; //Password
        Connection conn = null;
        Statement stmt = null;
        String url = "jdbc:clickhouse://" + IP + ":8123";
        try {
            Class.forName("com.mysql.jdbc.Driver");
            conn = DriverManager.getConnection(url, USER, PASS);
            stmt = conn.createStatement();
            String sql = "show databases;";
            ResultSet rs = stmt.executeQuery(sql);
            int columns = rs.getMetaData().getColumnCount();
            for (int i = 1; i <= columns; i++) {
                System.out.print(rs.getMetaData().getColumnName(i));
                System.out.print("\t");
            while (rs.next()) {
                System.out.println();
                    System.out.print(rs.getObject(i));
            rs.close();
            stmt.close();
            conn.close();
        } catch (SQLException se) {
            se.printStackTrace();
        } catch (Exception e) {
        } finally {
            // release resource ....
