Help Center/
TaurusDB/
User Guide/
HTAP Analysis (Standard Edition)/
Standard HTAP Instance Management/
Rebooting a Node of a Standard HTAP Instance
Updated on 2024-11-06 GMT+08:00
You may need to reboot a node of an HTAP instance for maintenance reasons.
- You can reboot a node only when it is available or abnormal. When some operations such as creating a task, changing specifications, scaling up storage, and upgrading a minor version, are being performed on a node, the node cannot be rebooted.
- It takes about 1 to 2 minutes to reboot a node of an HTAP instance. During the reboot, the instance is unavailable. Rebooting a node will clear its cache. To prevent traffic congestion during peak hours, you are advised to reboot the node during off-peak hours.
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page, choose .
- On the Instances page, locate a GaussDB(for MySQL) instance and click its name to access the Basic Information page.
- In the navigation pane, choose HTAP Analysis. Locate an HTAP instance and click its name to access the Basic Information page.
- Locate an HTAP node and click Reboot in the Operation column.
- In the displayed dialog box, click OK to reboot the node. It takes about 1 to 2 minutes.
