Help Center/
GaussDB(for MySQL)/
User Guide/
DBA Assistant/
SQL Analysis and Tunning/
Viewing Top SQL Statements
Updated on 2024-09-24 GMT+08:00
After Collect All SQL Statements is enabled, you can gain a comprehensive insight into SQL statements on the SQL Explorer page. Top SQL helps you locate exceptions.
- Click in the upper left corner and select a region and project.
- Click in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- On the Instances page, click the instance name.
- In the navigation pane, choose DBA Assistant > Historical Diagnosis.
- Choose SQL Explorer > Top SQL.
- Top SQL needs to be purchased separately. To use this function, subscribe to Intelligent O&M first.
- Only the data of the last hour is displayed if Intelligent O&M is not subscribed. The data will be automatically deleted after one hour. If Intelligent O&M is subscribed, you can configure how long that top SQL statements are stored for (spanning no more than one day).
- Click Subscribe. In the displayed dialog box, you can learn about Intelligent O&M functions and pricing.
Figure 1 Subscribing to Intelligent O&M
- View the top SQL statements of the DB instance.
Figure 2 Viewing top SQL statements
- You can view execution durations of the top SQL statements in the last 1 hour, last 3 hours, last 12 hours, or a custom time period (spanning no more than one day).
- Click a point in time or drag to select a time period to view the SQL statistics of an SQL template.
- Click to export information about all top SQL templates in the list. To use this export function, subscribe to Intelligent O&M.
- Locate an SQL template and click Details to view the total execution times, average rows scanned, average execution duration, and the like.
- Locate an SQL template and click Concurrency Control in the Operation column. For details, see Using SQL Statement Concurrency Control.
- Select Comparison by Date and select dates and a time range to view the top SQL statements in the time range on different days.
Figure 3 Comparing top SQL statements
