Creating an Account
When you create a GaussDB(for MySQL) instance, account root is created at the same time by default. You can create other database accounts as needed.
This operation is not allowed when another operation is being performed on your DB instance.
Method 1: Creating an Account on the GaussDB(for MySQL) Console
- Click in the upper left corner and select a region and project.
- Click in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- On the Instances page, click the instance name.
- In the navigation pane, choose Accounts.
- On the displayed page, click Create Account.
- In the displayed dialog box, set the required parameters.
Figure 1 Creating an account
Table 1 Parameter description Parameter
Username
The username can consist of 1 to 32 characters. Only lowercase letters, digits, and underscores (_) are allowed.
Host IP Address
- To enable all IP addresses to access your DB instance, enter % for Host IP Address.
- To enable all IP addresses in the subnet 10.10.10.* to access your DB instance, enter 10.10.10.% for Host IP Address.
- To specify multiple IP addresses, separate them with commas (,), for example, 192.168.0.*,172.16.213.* (no spaces before or after the comma).
Database
You can select one or more unauthorized databases and authorize their permissions to the account. If there are no unauthorized databases, you can create ones. You can also modify the database permissions after the account is created.NOTE:- If you do not delete a database on the GaussDB(for MySQL) console but delete a database in other ways, permissions granted specifically for the database are not automatically deleted. They must be deleted manually. This is an open-source MySQL behavior. For details, see DROP DATABASE Statement.
- If you require fine-grained permissions control, log in to the DAS console.
Password
The password must:
- Consist of 8 to 32 characters.
- Contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters ~!@#$%^*-_=+?,()&|.
- Comply with the values of validate_password parameters.
To check the password-related parameter values, click an instance name, choose Parameters in the navigation pane, and search for validate_password in the upper right corner of the page.Figure 2 Checking the password-related parameters
- Be different from the username or the username spelled backwards.
Confirm Password
The value must be the same as that of Password.
Remarks
The remarks can consist of up to 512 characters. It cannot contain carriage returns or any of the following special characters: !<"='>&
- Click OK.
- After the account is created, you can manage it on the Accounts page of the selected instance.
Method 2: Creating an Account Through DAS
- On the Instances page, locate the target instance and click Log In in the Operation column.
- On the displayed DAS login page, enter the username and password and click Log In.
- Create an account.
You can use either of the following methods to create an account:
- Choose SQL Operations > SQL Query. In the displayed SQL window, select the target database and run the following command:
create user username;
- Choose Create User.
For detailed operations and parameter settings, see Creating a User.
and click
