On this page
Show all
Backup Types
Updated on 2024-11-06 GMT+08:00
Based on different dimensions, there are the following backup types in GaussDB(for MySQL).
  • Full backups and incremental backups based on data volume
    Table 1 Comparison between full backups and incremental backups
    Backup Type
    Full backups
    Incremental backups
    All data in your DB instance is backed up.
    Only data that has changed within a certain period is backed up.
    Enabled by Default
    Yes
    Yes
    Retention Period
    Full backups are retained till the retention period expires.
    Incremental backups are retained till the retention period expires.
    Characteristic
    • A full backup is to back up all data of your DB instance in the current point of time.
    • You can use a full backup to restore the complete data generated when the backup was created.
    • Full backups include automated backups and manual backups.
    • GaussDB(for MySQL) automatically backs up the updated data since the last automated or incremental backup was made every five minutes or after a certain amount of data is reached.
    • Incremental backups are automated backups.
    • Incremental backups are created based on the most recent full backup, as shown in Figure 1, so the most recent full backup that exceeds the retention period is still retained. For details, see the following example.
      Figure 1 Incremental data restoration
    How to View
    Click the instance name. On the Backups page, click the Full Backups tab and view the backup size.
    Click the instance name. On the Backups page, click the Incremental Backups tab and view the backup size.
  • Automated backups and manual backups based on backup methods
    Table 2 Comparison between automated backups and manual backups
    Backup Type
    Automated backups
    Manual backups
    • You can set an automated backup policy on the management console, and the system will automatically back up your instance data based on the time window and backup cycle you set in the backup policy and will store the data for the retention period you specified.
    • Automated backups cannot be manually deleted. To delete them, you adjust the retention period specified in your backup policy. Retained backups (including full and incremental backups) will be automatically deleted at the end of the retention period.
    • Manual backups are user-initiated full backups of your DB instance. They are retained until you delete them manually.
    • Regularly backing up your DB instance is recommended, so if your DB instance becomes faulty or data is corrupted, you can restore it using backups.
    Enabled by Default
    Yes
    Yes
    Retention Period
    Automated backups are retained for the retention period you specified.
    The backup retention period ranges from 1 to 732 days.
    Manual backups are always retained until you delete them manually.
    Configuration
    Configuring a Same-Region Backup Policy
    Creating a Manual Backup
  • Same-region backups and cross-region backups based on backup regions
    To configure cross-region backup policies, contact customer service.
    Table 3 Comparison between same-region backups and cross-region backups
    Backup Type
    Same-region backups
    Cross-region backups
    Backups are stored in the same region as your DB instance.
    Backups are stored in a different region from that of your DB instance.
    Enabled by Default
    Yes
    No
    Retention Period
    Same-region backups are retained for the retention period you specified.
    You can contact customer service to extend the backup retention period to up to 3,660 days.
    Cross-region backups are retained for the retention period you specified.
    The backup retention period ranges from 1 to 1,825 days.
    Characteristic
    Backups are stored in the same region as your DB instance. Same-region backup (automated backup) is enabled by default and cannot be disabled.
    Backups are stored in a region different from the region where your DB instance is located. After you enable cross-region backup, the backups are automatically stored in the region you specify.
    Configuration
    Configuring a Cross-Region Backup Policy
    How to View
    • If cross-region backup is enabled:
      Click Backups in the navigation pane. On the Same-Region Backups tab, view the backup size.
    • If cross-region backup is not enabled:
      Click Backups in the navigation pane and view the backup size.
    Click Backups in the navigation pane. On the Cross-Region Backups tab, locate a DB instance and click View Cross-Region Backup in the Operation column.
