Rebooting a DB Instance or Node
You may need to reboot a GaussDB(for MySQL) instance or node for maintenance purposes. For example, after modifying some parameters, you may need to reboot your instance to apply the modifications. You may need to reboot a node to resolve database connection issues.
- If the DB instance status is Abnormal, the reboot may fail.
- To shorten the time required, reduce database activities during the reboot to reduce rollback of transit transactions.
- Rebooting a DB instance will interrupt services briefly. During this period, the instance status is Rebooting.
- A DB instance will be unavailable when it is being rebooted. Rebooting a DB instance will clear the cached memory in it. To prevent traffic congestion during peak hours, you are advised to reboot the DB instance during off-peak hours.
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page and choose Databases > GaussDB(for MySQL).
- On the Instances page, locate the instance you want to reboot and choose
in the Operation column.
Alternatively, click the instance name to go to the Basic Information page. Click Reboot in the upper right corner of the page.
The read replicas are also rebooted.
- If you have enabled operation protection, click Start Verification in the displayed dialog box. On the displayed page, click Send Code, enter the obtained verification code, and click Verify to close the page.
For details about how to enable operation protection, see Identity and Access Management User Guide.
- In the Reboot DB Instance dialog box, set Scheduled Time.
Figure 1 Rebooting a DB instance
Table 1 Rebooting a DB instance Parameter
Scheduled Time
You can reboot a DB instance immediately or during the maintenance window.
- Immediate: The DB instance will be rebooted immediately.
- During maintenance window: The DB instance will be rebooted during a maintenance window.
The maintenance window is 02:00–06:00 by default and you can change it as required. Changing the maintenance window will not affect the timing that has already been scheduled.
A reboot task configured during a current maintenance window will not be executed until the next maintenance window.
- Click OK.
- View the reboot progress on the Task Center page. If the task status becomes Completed and the instance status becomes Available, the DB instance has been rebooted successfully.
- Nodes in the Abnormal state can be rebooted.
- Rebooting a node will interrupt services briefly. During this period, the node status is Rebooting node.
- A node will be unavailable when it is being rebooted. You are advised to reboot the node during off-peak hours and ensure that your applications support automatic reconnection.
- If a parameter of your DB instance is modified, you need to first reboot the DB instance to apply the modification, and then reboot a node of the DB instance.
- Click
- Click
- On the Instances page, click the instance name to go to the Basic Information page.
- In the Node List area, select the target node and click Reboot in the Operation column.
- In the displayed dialog box, set Scheduled Time.
Table 2 Rebooting a node Parameter
Scheduled Time
You can reboot a node immediately or during the maintenance window.
- Immediate: The node will be rebooted immediately.
- During maintenance window: The node will be rebooted during a maintenance window.
- Click Yes.
- View the reboot progress on the Task Center page. If the task status becomes Completed and the node status becomes Available, the node has been rebooted successfully.
- Click
- Click
Scheduled Time
- Click OK.
- Click
- Click
Scheduled Time
- Click Yes.
