Updated on 2025-11-07 GMT+08:00
Removing an Endpoint
You can remove an endpoint if you no longer need it.
After the endpoint is removed, the global accelerator will no longer forward requests to it.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click Endpoint Groups.
- On the right of the page, locate the endpoint and click Remove in the Operation column.
You can select more than one endpoint at a time and click Remove above the list to delete them all.
- In the displayed dialog box, click Yes.
Parent topic: Endpoints
