- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Managing Listener Tags
After a listener is created, you can view its tags or add, edit or delete a tag.
A tag is the identifier of a listener and consists of a key and a value. You can add up to 20 tags to a listener.
If a predefined tag has been created in TMS, you can select the corresponding tag key and value.
For details about predefined tags, see Predefined Tag Overview.
If you have configured tag policies for Global Accelerator, you need to add tags to listeners based on the tag policies. If you add a tag that does not comply with the tag policies, listeners may fail to be created. Contact the administrator to learn more about tag policies.
Adding a Tag
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click the Listeners tab.
- In the right pane of the listener page, click the Tags tab.
- Click Add Tag.
- In the displayed dialog box, enter a key and a value, and click Add.
If you have configured tag policies for Global Accelerator, you need to add tags to your listeners based on the tag policies. If you add a tag that does not comply with the tag policies, listeners may fail to be created. Contact the administrator to learn more about tag policies.
Table 1 describes the tag key and value requirements.
Table 1 Tag key and value requirements Parameter
Requirements
Tag key
- Cannot be left blank.
- Can contain letters, digits, spaces, underscores (_), periods (.), colons (:), equal signs (=), plus signs (+), hyphens (-), and at signs (@).
- Cannot start or end with a space.
- Cannot start with _sys_.
- Can contain a maximum of 128 characters.
Tag value
- Can be left blank.
- Can contain letters, digits, spaces, underscores (_), periods (.), colons (:), slashes (/), equal signs (=), hyphens (-), and at signs (@).
- Can contain a maximum of 255 characters.
- Click OK.
Editing a Tag
Modify the value of a tag added to a listener.
- In the tag list, locate the tag you want to modify and click Edit in the Operation column.
- Enter a new value.
- Click OK.
Deleting a Tag
Delete a tag added to a listener.
Deleted tags cannot be recovered.
- In the tag list, locate the tag you want to delete and click Delete in the Operation column.
- Click Yes.
