On this page
Adding a Listener
You can add a listener to a global accelerator so that the listener can listen to requests and distribute them to the associated endpoints based on the client affinity and weight you set.
  1. Log in to the Global Accelerator console.
  2. Search for the global accelerator by name or ID.
  3. Click the name of the global accelerator to go to the details page.
  4. Click Listeners.
  5. Click Add Listener.
  6. Specify the parameters listed in Table 1.
    Table 1 Parameters required for adding a listener
    Item
    Basic Configuration
    Name
    Listener name.
    You can enter up to 64 characters. Only letters, digits, and hyphens are allowed.
    Protocol
    The protocol used by the listener to receive requests from clients.
    The protocol can be TCP or UDP.
    Port
    The ports or port ranges used by the listener to receive requests from clients.
    The port number ranges from 1 to 65535. You can enter one or more ports or port ranges separated by commas (,).
    Example: 1-10,11-50,51,52-200
    Client Affinity
    • If you select None, the listener routes requests evenly among the endpoints in the endpoint group.
    • If you select Source IP address, the source IP address of each request is calculated using the consistent hashing algorithm to obtain a unique hash key, and all the endpoints are numbered and mapped to the hash keys. Requests from the same IP address are forwarded to the same endpoint for processing.
    TCP and UDP listeners support only Source IP address.
    Tags
    The identifier of a listener. Each tag consists of a key and a value. You can add up to 20 tags to a listener.
    Supplementary information about the listener.
    You can enter up to 255 characters.
    Endpoint Groups
    Name
    Name of the endpoint group.
    Each listener can be associated with only one endpoint group in a given region.
    Region
    Region where the endpoint group is used.
    Supplementary information about the endpoint group.
    Traffic Dial
    The percentage of traffic directed to the endpoint group.
    If you increase the traffic dial, more requests will be distributed to this endpoint group.
    If you set the traffic dial to 0, no requests will be distributed to this endpoint group.
    The weight ranges from 0 to 100.
    If a listener has multiple endpoint groups, traffic will be first distributed to the endpoint group with the lowest latency and then to other endpoint groups based on the traffic dial value you set.
    Endpoint
    An endpoint serves as a single point of contact for clients, and Global Accelerator distributes incoming traffic across healthy endpoints.
    Health Check
    Health Check
    Whether to enable health check.
    If you disable health check, requests may be forwarded to unhealthy endpoints.
    Protocol
    The health check protocol can be TCP.
    Default value: TCP.
    Port
    The port used for health check.
    Advanced Settings
    Interval (s)
    The maximum time between two consecutive health checks, in seconds.
    The interval ranges from 1 to 60.
    Timeout (s)
    The maximum time required for waiting for a response to a health check request, in seconds.
    The timeout ranges from 1 to 60.
    Maximum Retries
    The maximum number of health check retries allowed.
    The value ranges from 1 to 10.
  7. Click OK.
