Listener Overview
Each global accelerator has at least one listener for listening to requests and distributing the requests to endpoints based on the client affinity and weight you set.
Protocols Supported by Listeners
OSI Layer |
Protocol |
Description |
Scenarios |
Layer 4 |
TCP |
Layer 4 |
UDP |
Video chats, gaming, real-time financial quotations, and other scenarios that require quick response |
Listening Ports
Protocol |
Port Range |
Description |
TCP |
1–65535 |
Port 22 is used by the system and is not recommended. Multiple ports or port ranges are separated by commas (,). |
UDP |
1–65535 |
Port 4789 is used by the system and is not recommended. Multiple ports or port ranges are separated by commas (,). |
