Updated on 2025-07-16 GMT+08:00
Access Logging
Global Accelerator logs requests sent to listeners, including the time when the request was sent, client IP address, request path, and server response.
Log Tank Service (LTS) is a regional service. You can enable access logging for Global Accelerator in CN North-Beijing4 and AP-Singapore as needed.
To enable access logging, you need to interconnect Global Accelerator with LTS and create a log group and a log stream on the LTS console by following the instructions in the Log Tank Service User Guide.
Configuring LTS
  1. Create a log group.
    2. In the upper left corner of the page, click and select the desired region and project.
    3. In the upper left corner of the page, click and select Log Tank Service under Management & Governance.
    1. In the navigation pane on the left, choose Log Management.
    2. Click Create Log Group. In the displayed dialog box, enter a name for the log group.
      Set Log Retention Duration as required.
    1. Click OK.
  2. Create a log stream.
    1. On the LTS console, click on the left of a log group name.
    2. Click Create Log Stream. In the displayed dialog box, enter a name for the log stream.
    3. Select an enterprise project as required.
    4. Click OK.
Configuring Access Logging
  1. Log in to the Global Accelerator console.
  2. Click the name of the global accelerator to go to the details page.
  3. Click Access Logs.
  4. Click Configure Access Logging.
  1. Enable access logging and select the log group and log stream you created.
  2. Click OK.
Viewing Access Logs
  4. In the access log list, locate the target access log and click View Log Details.
    On the displayed page, view the information about the log group and log stream.
  5. Click the name of the log stream and view its details.
    The following is an example log. For details about the fields in the log, see Table 1. The log format cannot be modified.
           "content": "conn_state_time:$value, conn_type: $value, conn_state: $value, proto: $value, client_ip: $value, client_port: $value, listener_ip: $value, local_ip: $value, local_port: $value, dest_ip: $value, dest_port: $value ",
           "_resource_id": "$value ",
           "_resource_name": "LISTENER",
           "_service_type": "GA",
           "category": "LTS",
           "collectTime": $value
    Table 1 Parameter description
    Value Description
    Example Value
    conn_state_time
    Session creation/aging time
    String
    2024-01-02 09:22:56
    conn_type
    Session type recorded in the flow log
    CREATE: information about new connections
    EXPIRE: information about expired connections
    CREATE
    conn_state
    Session status when a session is recorded
    String
    ESTABLISHED
    proto
    The protocol type of a session
    TCP: TCP connections
    UDP: UDP connections
    TCP
    client_ip
    Source IP address of a session
    IP address
    127.0.0.1
    client_port
    Source port of a session
    Port number
    12345
    listener_ip
    IP address used by the accelerator
    IP address
    127.0.0.1
    local_ip
    The IP address used to communicate with endpoints
    IP address
    127.0.0.1
    local_port
    The port used to communicate with endpoints
    Port number
    24687
    dest_ip
    The IP address used by the endpoint
    IP address
    127.0.0.1
    dest_port
    The port of the endpoint
    Port number
    80
    _resource_id
    Resource ID
    uuid
    95c2b814-99dc-939a-e811-ae84c61ea9ee
    _resource_name
    Resource type
    Fixed value: LISTENER
    LISTENER
    _service_type
    Service corresponding to the flow log.
    Fixed value: GA
    GA
    category
    Log category
    Fixed value: LTS
    LTS
    collectTime
    LTS log collection time
    Integer
    1704158708902
Configuring Log Transfer
If you want to analyze access logs later, transfer the logs to OBS for storage.
  1. In the navigation pane on the left, choose Log Transfer.
  2. On the Log Transfer page, click Configure Log Transfer in the upper right corner.
    Figure 1 Configuring log transfer
  1. Configure the parameters. For details, see the Log Tank Service User Guide.
