- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Viewing an IP Address Group
You can view the details of an IP address group on the Global Accelerator console, including its name/ID, status, description, creation time, CIDR blocks, associated listeners, listener protocol/port, and access control policies.
- Go to the IP Address Groups page.
- On the displayed page, search for the target IP address group by name or ID.
- Click the name of the IP address group to view the following information:
- Basic information: name/ID, status, description, and creation time
- CIDR blocks: IP addresses and description
- Associated listeners: name, listener protocol/port, and access control policies
Parent topic: IP Address Groups
