- What's New
- Function Overview
- Billing
Getting Started
- Creating a Function from Scratch and Executing the Function
- Creating a Function Using a Template and Executing the Function
- Creating an HTTP Function Using a Container Image and Executing the Function
- Creating an Event Function Using a Container Image and Executing the Function
- Getting Started with Common Practices
User Guide
- Replacing the Temporary AK/SK
- Before You Start
- Building Functions
Configuring Functions
- Configuring Initialization
- Configuring Basic Settings
- Configuring Agency Permissions
- Configuring the Network
- Configuring Disk Mounting
- Configuring Environment Variables
- Configuring Asynchronous Execution Notification
- Configuring Single-Instance Multi-Concurrency
- Managing Versions
- Managing Aliases
- Configuring Dynamic Memory
- Configuring Heartbeat Function
- Configuring Tags
- Configuring Snapshot-based Cold Start
- Configuring a Log Group and Log Stream
- Stateful Functions
- Shared VPC
- Online Debugging
Creating Triggers
- Managing Triggers
- Using a Timer Trigger
- Using an APIG (Dedicated) Trigger
- Using a Kafka Trigger
- Using a DIS Trigger
- Using an SMN Trigger
- Using an LTS Trigger
- Using a CTS Trigger
- Using a DDS Trigger
- Using a GeminiDB Mongo Trigger
- Using an APIG Trigger
- Using an APIC Trigger
- Using a DMS (for RabbitMQ) Trigger
- Using an Open-Source Kafka Trigger
- Cron Expressions for a Function Timer Trigger
- Using an EG Trigger
- Invoking the Function
- Monitoring
- Function Management
- Dependency Management
- Reserved Instance Management (Old)
- Flow Management
- Increasing Resource Quota
- GPU Function Management
- Application Center
- Sharing
- Programmable CDN Function
- CLI Command Reference
- Audit
Best Practices
- FunctionGraph Best Practices
- Processing DIS Data
- Integrating with LTS to Analyze Logs in Real Time
- Integrating with CTS to Analyze Login/Logout Security
- Periodically Starting or Stopping Huawei Cloud ECSs
- Building an HTTP Function with Spring Boot
- Creating a FunctionGraph Backend API That Uses a Custom Authorizer
- Uploading Files with FunctionGraph and APIG
- Processing IoT Data
- Workflow + Function: Automatically Processing Data in OBS
- Filtering Logs in Real Time by Using FunctionGraph and LTS
- Deploying AI Drawing Stable-Diffusion in the Application Center
- Building an HTTP Function with Go
- Using FunctionGraph HTTP Functions to Process gRPC Requests
- Cold Start Optimization Practices
Developer Guide
- Overview
- Initializer
- Node.js
- Python
- Java
- Go
- C#
- PHP
- Development Tools
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
- Extension and OpenTelemetry APIs
APIs
- Function Invocation
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
Function Lifecycle Management
- Querying Functions
- Deleting a Function or Function Version
- Querying the Code of a Function
- Modifying the Code of a Function
- Querying the Metadata of a Function
- Modifying the Metadata of a Function
- Updating Max. Instances of a Function
- Querying Function Tags
- Enabling or Disabling the Snapshot Function
- Querying ServiceBridge Functions Bound to a Specified Function
- Querying Snapshot Status
- Querying Resource Tags
- Querying Resources
- Deleting Resource Tags
- Creating Resource Tags
- Creating a VPC Endpoint
- Deleting a VPC Endpoint
- Updating the Pinning Status of a Function
- Querying the Available ServiceBridge Version
- Versions and Aliases
- Function Metrics
- Function Logs
- Function Templates
- Reserved Instances
- Function Import and Export
- Function Triggers
Function Flows
- Executing a Flow Synchronously
- Executing a Flow Asynchronously
- Deleting Flows
- Querying a Flow
- Creating a Flow
- Querying Instances of a Flow
- Querying a Flow Instance
- Querying Metadata of a Flow Instance
- Modifying Metadata of a Flow Instance
- Querying Flow Metrics
- Querying Metrics of a Flow
- Re-executing a Flow
- Stopping a Flow
- Querying Records of a Flow in Pagination Mode
- Calling Back a Flow
- Querying Asynchronous Execution Notification Settings of a Function Version
- Deleting Asynchronous Execution Notification Settings
- Querying Asynchronous Execution Notification Settings of a Function's All Versions
- Querying Asynchronous Invocation Requests
- Querying Active Asynchronous Invocation Requests
- Stopping an Asynchronous Invocation Request
- Appendix
- Change History
- SDK Reference
General FAQs
- What Is FunctionGraph?
- Do I Need to Apply for Any Compute, Storage, or Network Services When Using FunctionGraph?
- Do I Need to Deploy My Code After Programming?
- How Do I Obtain a Token?
- What Runtimes Does FunctionGraph Support?
- How Much Disk Space Is Allocated to Each FunctionGraph Function?
- Does FunctionGraph Support Function Versioning?
- How Does a Function Read or Write Files?
- How Do I Set a Proxy When Using CLI?
- Does FunctionGraph Support Function Extension?
- Which Permissions Are Required for an IAM User to Use FunctionGraph?
- How Can I Create an ODBC Drive-based Python Dependency Package for Database Query?
- What Is the Quota of FunctionGraph?
- What Chinese Fonts Does FunctionGraph Support?
- How Does FunctionGraph Resolve a Private DNS Domain Name?
- How Does a Container Image–based Function Resolve a Private DNS Domain Name?
- How Do I Use a Domain Name to Access an API Registered with API Gateway (Dedicated)?
- What Are the Common Application Scenarios of FunctionGraph?
- Why Can't the API Gateway Domain Name Bound to a Service Be Resolved During Function Invocation?
- Does FunctionGraph Support Synchronous Transmission at the Maximum Intranet Bandwidth?
- What If the VPC Quota Is Used Up?
- How Can I Print Info, Error, or Warn Logs?
- Can I Set the Domain Name of an API to My Own Domain Name?
- Can I Change the Runtime?
- Can I Change a Function's Name?
- Why Is Message "failed to mount exist system path" Displayed?
- How Do I Obtain Uploaded Files?
- Why Can't I Receive Responses for Synchronous Invocation?
- What Should I Do If the os.system("command &") Execution Logs Are Not Collected?
- Which Directories Can Be Accessed When a Custom Runtime Is Used?
- Which Minor Versions of Python 3.6 and 3.9 Are Supported?
- Which Actions Can Be Used Instead of a VPC Administrator Agency for VPC Access?
- What Are the Possible Causes for Function Timeout?
- How Do I Obtain the Code of a Function?
- Do You Have Sample Code for Initializers?
- How Do I Enable Structured Log Query?
- Can I Enable a Listening Port in a Function to Receive External TCP Requests via EIP?
- Does FunctionGraph Support Domain Name Resolution?
- How Do I Obtain the Source IP Address of an HTTP Request Initiated by a Function?
- Function Creation FAQs
Trigger Management FAQs
- What Events Can Trigger a FunctionGraph Function?
- What If Error Code 500 Is Reported When Functions that Use APIG Triggers Return Strings?
- What Do LATEST and TRIM_HORIZON Mean in DIS Trigger Configuration?
- How Do I Use an APIG Trigger to Invoke a Function?
- How Does a Function Obtain the Request Path or Parameters When Using an APIG Trigger?
- Can I Configure a Kafka Trigger in a Different Subnet from My Function?
Dependency Management FAQs
- What Is a Dependency?
- When Do I Need a Dependency?
- What Are the Precautions for Using a Dependency?
- What Dependencies Does FunctionGraph Support?
- Does FunctionGraph Support Class Libraries?
- How Do I Use Third-Party Dependencies on FunctionGraph?
- How Do I Create Function Dependencies?
- How Do I Create a Dependency on the FunctionGraph Console?
- How Do I Add a Dependency to a Function?
Function Execution FAQs
- How Long Does It Take to Execute a FunctionGraph Function?
- Which Steps Are Included in Function Execution?
- How Does FunctionGraph Process Concurrent Requests?
- What If Function Instances Have Not Been Executed for a Long Time?
- How Can I Speed Up Initial Access to a Function?
- How Do I Know the Actual Memory Used for Function Execution?
- Why Is My First Request Slow?
- What Do I Do If an Error Occurs When Calling an API?
- How Do I Read the Request Header of a Function?
- Can the Synchronous Execution Interface Be Invoked on a Private Network?
- Why Does a Function Use More Memory Than Estimated and Even Trigger the Out of Memory Alarm?
- How Do I Check the Memory Usage When Seeing "runtime memory limit exceeded"?
- How Do I Troubleshoot "CrashLoopBackOff"?
- After I Updated an Image with the Same Name, Reserved Instances Still Use the Old Image. What Can I Do?
- Function Configuration FAQs
- External Resource Access FAQs
Other FAQs
- How Do I View the Alarm Rules Configured for a Function?
- Does FunctionGraph Support ZIP Decompiling During Video Transcoding?
- Will Resources Created During FunctionGraph 2.0 OBT Be Automatically Released When They Expire? Will Them Be Billed?
- What Is an App in FunctionGraph?
- Do I Need to Pay for Cold Start Time?
- Why Am I Seeing a Message Indicating that My Account Was Suspended When Creating a Function?
- Will the Requests of All My Functions in Different Regions Be Billed?
- Migration from FunctionGraph V1 to V2
General FAQs
More Documents
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Why Can't I Enable or Disable OBS Triggers by Calling APIs?
- Can I Create an OBS Trigger with an Existing Bucket?
- Other FAQs
General FAQs
- Before You Start
- API Overview
- Calling APIs
- Function Model Definition
Function Management Zone APIs
- Querying a Function List
- Publishing a Function Version
- Querying the Versions of a Function
- Creating an Alias for a Function Version
- Modifying the Alias Information About a Function Version
- Deleting an Alias of a Function Version
- Querying the Alias Information About a Function Version
- Querying the Version Alias List of a Function
- Querying All Triggers of a Function
- Querying the Information About a Trigger
- Deleting All Triggers of a Function
- Creating a Trigger
- Deleting a Trigger
- Function Data Zone APIs
- Appendix
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Other FAQs
General FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
- Function Metrics
- Function Logs
- Function Triggers
- Appendix
- Developer Guide (Kuala Lumpur Region)
- Videos
On this page
Precautions
- Currently, stateful functions are only available in AP-Singapore.
- A stateful function cannot recursively invoke itself.
- Return values of Java functions can only be in JsonObject.
- The size of a single state cannot exceed 256 KB. Each tenant can create a maximum of 100 stateful function instances.
- State data is not encrypted during execution and persistence. Encrypt your sensitive data if any.
- Stateful functions do not support reserved instances.
- instanceName can contain 1 to 128 letters and digits.
- Functions that access or are accessed by resources in a VPC must be in the same subnet as the resources.
Special init Method of Node.js
Node.js functions have an init() method for initialization and generating instance IDs.
To invoke a stateful function, use the following code:
const f = new Function(context, functionName, instanceName); await f.init();
Parent topic: Stateful Functions
