Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus X Instance/ User Guide/ VPC Management/ Changing the Private IP Address of the Primary Network Interface for a FlexusX Instance
Updated on 2025-12-04 GMT+08:00
You can change the private IP address of the primary network interface for a FlexusX instance on the console.
- The FlexusX instance must be stopped.
- If a virtual IP address or DNAT rule has been configured for the network interface, cancel the configuration before modifying the private IP address.
- If the network interface has an IPv6 address, its private IPv4 or IPv6 address cannot be modified.
- To change the private IP address for a backend server of a load balancer, remove the backend server from the backend server group first.
- Log in to the FlexusX console. In the upper left corner, click
and select a region. - In the FlexusX instance list, click the name of the FlexusX instance whose private IP address is to be changed.
- On the Network Interfaces tab, locate the primary network interface and click Modify Private IP.
The Modify Private IP dialog box is displayed.
- Change the subnet and private IP address of the primary network interface as required.
- Subnet: Select a subnet. Subnets can be changed only within the same VPC.
- New Private IP Address: Specify a new private IP address. If you do not specify a private IP address, the system will automatically assign one to the primary network interface.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
