Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus X Instance/ User Guide/ VPC Management/ Detaching Extended Network Interfaces from a FlexusX Instance
Updated on 2025-12-04 GMT+08:00
You can detach extended network interfaces from your FlexusX instance if they are no longer needed. Only extended network interfaces can be detached from the FlexusX instance. You cannot detach the primary network interface from it.
This section describes how to detach an extended network interface on the console.
  1. Log in to the FlexusX console. In the upper left corner, click and select a region.
  2. In the FlexusX instance list, click the name of the FlexusX instance that you want to detach a network interface from.
    The details page of this instance is displayed.
  3. On the Network Interfaces tab, choose More > Detach.
    You are not allowed to delete the primary network interface from this instance. By default, the primary network interface is the first one in the list.
  4. Click OK in the displayed dialog box.
    Some FlexusX instances do not allow to you detach network interfaces while the instances are running. For details, see the on-screen instructions. To detach a network interface from such a FlexusX instance, stop the instance first.
