- Getting Started
User Guide
- Using IAM to Grant Access to FlexusX
- Purchasing a FlexusX Instance
- Logging In to a FlexusX Instance
- Managing FlexusX Instances
- Managing Images
- Managing EVS Disks
VPC Management
- VPC Overview
- Attaching Extension Network Interfaces to a FlexusX Instance
- Detaching Extension Network Interfaces from a FlexusX Instance
- Changing the VPC for a FlexusX Instance
- Changing the Private IP Address of the Primary Network Interface for a FlexusX Instance
- Configuring a Virtual IP Address for a FlexusX Instance
- Managing EIPs
- Managing Server Security
- Managing Backups
- Viewing Monitoring Metrics and Configuring Alarms
- API Reference
- Product Consulting
- Billing
- OS and Image
- Specification Modification FAQ
Performance Mode
- How Do I Know Whether Performance Mode Is Enabled for a FlexusX Instance?
- How Much Can Performance Be Improved If Performance Mode Is Enabled for a Flexus X Instance?
- Do I Need to Stop My FlexusX Instance If I Want to Enable or Disable Performance Mode for It?
- Can I Enable Performance Mode After a FlexusX Instance Is Created?
- Will I Continue to Be Billed If I Disable Performance Mode for My FlexusX Instance?
- Password
Show all
An elastic network interface is a virtual network interface that can be attached to a FlexusX instance in a VPC. You can use network interfaces to manage networks for FlexusX instances. There are two types of elastic network interfaces: primary network interfaces and extension network interfaces.
- A primary network interface is created together with an instance by default, and cannot be detached from the instance.
- An extended network interface can be created on the Network Interfaces tab, and can be attached to or detached from an instance.
If your FlexusX instance requires multiple network interfaces, you can attach extension network interfaces. For details, see Elastic Network Interface Overview.
- Log in to the FlexusX console, in the upper left corner, click
, and select a region.
- In the FlexusX instance list, click the name of the FlexusX instance that you want to attach a network interface to.
- On the Network Interfaces tab, click Attach Network Interface.
You can use an existing extension network interface or create a new one.Figure 1 Attaching an extension network interface
- Subnet: This parameter is mandatory. You need to select a subnet where the network interface will work.
- New Private IP Address: This parameter is optional. You can specify a private IP address for the network interface. If it is not specified, the system assigns a private IP address automatically.
- Security Group: This parameter is mandatory. You can select multiple security groups at a time. The rules of all the selected security groups are applied to the FlexusX instance.
- Click OK.
Related Operations
After an extension network interface is attached to a FlexusX instance, you are advised to enable NIC multi-queue to improve network performance. For details, see Enabling NIC Multi-Queue.
