- Getting Started
User Guide
- Using IAM to Grant Access to FlexusX
- Purchasing a FlexusX Instance
- Logging In to a FlexusX Instance
- Managing FlexusX Instances
- Managing Images
- Managing EVS Disks
VPC Management
- VPC Overview
- Attaching Extension Network Interfaces to a FlexusX Instance
- Detaching Extension Network Interfaces from a FlexusX Instance
- Changing the VPC for a FlexusX Instance
- Changing the Private IP Address of the Primary Network Interface for a FlexusX Instance
- Configuring a Virtual IP Address for a FlexusX Instance
- Managing EIPs
- Managing Server Security
- Managing Backups
- Viewing Monitoring Metrics and Configuring Alarms
- API Reference
- Product Consulting
- Billing
- OS and Image
- Specification Modification FAQ
Performance Mode
- How Do I Know Whether Performance Mode Is Enabled for a FlexusX Instance?
- How Much Can Performance Be Improved If Performance Mode Is Enabled for a Flexus X Instance?
- Do I Need to Stop My FlexusX Instance If I Want to Enable or Disable Performance Mode for It?
- Can I Enable Performance Mode After a FlexusX Instance Is Created?
- Will I Continue to Be Billed If I Disable Performance Mode for My FlexusX Instance?
- Password
Reinstalling the OS of a FlexusX Instance
If the OS of a FlexusX instance fails to start or requires optimization, reinstall the OS.
The target FlexusX instance has a system disk attached.
Notes
- After the OS is reinstalled, the IP address of the FlexusX instance remains unchanged.
- Reinstalling the OS clears the data in all partitions, including the system partition, of the system disk. Back up data before reinstalling the OS.
- Reinstalling the OS does not affect data disks.
- Do not perform any operations on the FlexusX instance immediately after its OS is reinstalled. Wait for several minutes while the system injects the password or key. Otherwise, the injection may fail, and the FlexusX instance cannot be logged in to.
- The FlexusX instance will automatically restart after the OS is reinstalled, and only custom settings (such as the DNS) will be reset.
Billing
OS reinstallation is free because the original image will be used.
- Log in to the FlexusX console, in the upper left corner, click
, and select a region.
- Locate the FlexusX instance and choose More > Manage Image > Reinstall OS in the Operation column.
- Specify the parameters required for reinstalling the OS.
- Select Stop FlexusX instance. The FlexusX instance must be stopped before its OS can be reinstalled.
- Set Login Mode. The credentials are used for logging in to the FlexusX instance.
- Password: A username and its initial password are used for FlexusX instance login authentication.
The initial password of user root is used for login authentication in Linux, and the initial password of user Administrator is used for login authentication in Windows.
- Key pair: A key pair is used for FlexusX instance login authentication. You can select an existing key pair, or click Create Key Pair to create a new one.
If you choose to use an existing key pair, ensure that it is available locally, or you will not be able to log in to your FlexusX instance.
- Password from image: If a password has been set for the private image, you can select this option to use that password.
- Set password later: You can choose to set a password for your FlexusX instance later. If you select this option, remember to set a password after your FlexusX instance is created.
- Click OK.
- On the Reinstall OS page, confirm the OS specifications, read and select the agreement or disclaimer, and click OK.
After the OS is reinstalled, the FlexusX instance will automatically restart. When the instance status is Running, the OS reinstallation is complete.
Follow-Up Operations
If the OS reinstallation fails, try again. If the second attempt still fails, submit a service ticket.
