Viewing Details of Failed Tasks
You can view the details of failed tasks (if any) in the Failures area, including the names and statuses of instances involved in the tasks.
- Log in to the FlexusX console. In the upper left corner, click
and select a region. Failure messages are displayed above the instance list.
- Click Failures to view failed task details. The following types of failures can be recorded in the Failures area.
Table 1 Task types Task Type
Creation failures
Failed FlexusX instance creation tasks.
Operation failures
Tasks with failed operations and error codes that help you troubleshoot the failures.
For a failed task, try again. If the failure persists, submit a service ticket to get technical support.
