Enabling Performance Mode for a FlexusX Instance
FlexusX provides flexible compute resources with QoS-guaranteed performance. FlexusX instances perform as well as exclusive instances most of the time but may occasionally underperform. To meet the strict performance requirements of certain workloads, such as rendering and HPC applications, FlexusX has a performance mode option. If this option is enabled, your FlexusX instances are bound with the underlying CPU cores, so they can provide stable, fantastic QoS-guaranteed performance.
Performance Mode | Enabled | Disabled |
Scenarios | Web 3.0 application development, rendering, cryptocurrency, ERP, game servers, e-commerce livestreaming, e-commerce going global, enterprise website building, applet development, and development and testing | E-commerce going global, enterprise website building, applet development, development and testing, enterprise resource planning (ERP), game servers, and e-commerce livestreaming |
vCPU allocation logic | CPU cores bound to provide QoS-guaranteed fantastic, stable performance | Flexible compute with QoS-guaranteed performance, close to exclusive instances |
x86 compute resources |
Kunpeng compute resources |
Precautions
During this process, you may also need to modify the instance specifications if there are insufficient underlying resources.
Billing
Additional charges are required for the performance mode.
You can enable performance mode for a FlexusX instance during or after the instance creation.
Performance mode is only available in some regions. For details, see the information displayed on the management console.
- Enabling performance mode when purchasing a FlexusX instance
Once the instance is created, you can enjoy stable, ample performance immediately.
Figure 1 Enabling performance mode during purchase
- Enabling performance mode after a FlexusX instance is purchased
You can enable performance mode for the instance using the Modify Specifications option. During this process, you may also need to modify the instance specifications if there are insufficient underlying resources. For details about how to modify specifications, see Modifying the Specifications of a FlexusX Instance.
Figure 2 Enabling performance mode using the Modify Specifications option
You may encounter the following issues when using performance mode:
- How Do I Know Whether Performance Mode Is Enabled for a FlexusX Instance?
- How Much Can Performance Be Improved If Performance Mode Is Enabled for a Flexus X Instance?
- Do I Need to Stop My FlexusX Instance If I Want to Enable or Disable Performance Mode for It?
- Can I Enable Performance Mode After a FlexusX Instance Is Created?
- Will I Continue to Be Billed If I Disable Performance Mode for My FlexusX Instance?
