Adding an EVS Disk to a FlexusX Instance
Disks attached to a FlexusX instance are classified as either system disks or data disks. A system disk is automatically created and attached when a FlexusX instance is created. You do not need to purchase the system disk separately.
Data disks can be purchased during or after the FlexusX instance creation. If you add a data disk when purchasing a FlexusX instance, the system automatically attaches the data disk to the FlexusX instance. If you buy a data disk after the FlexusX instance is purchased, you need to attach the data disk manually.
This section describes how to add a data disk after a FlexusX instance is created.
- Log in to the FlexusX console. In the upper left corner, click
and select a region. - Locate the FlexusX instance, and in the Operation column, choose More > Manage Disk/Backup > Add Disk.
- Configure parameters for the new EVS disk as prompted.
For instructions about how to set EVS disk parameters, see Purchasing an EVS Disk.
- Click Next to confirm the order and click Submit to complete the payment.
- Return to the FlexusX console and view the new data disk. Figure 1 Viewing the data disk
Helpful Links
After you add an EVS disk to a FlexusX instance, you still have to log in to the instance and initialize the disk before you can use it. For details about how to initialize a data disk, see Initializing a Data Disk.
Disks created from data sources, such as backups or snapshots, do not need to be initialized.
