Modifying the Bandwidth of a FlexusX Instance
If an EIP has been bound to a FlexusX instance, the instance can access the Internet using the bandwidth specified for the EIP. You can change the name, billing mode, and size of a bandwidth. This section describes how to modify the bandwidth of a FlexusX instance.
The rules for modifying EIP bandwidth vary depending on the billing mode of the EIP.
EIP Billing Mode | Billing Mode Changeable | Bandwidth Modification | Billing |
Yearly/Monthly | No |
Pay-per-use | Yes | You can increase or decrease the bandwidth. The modifications are applied immediately. | Pay-per-use billing is a postpaid mode, so after the bandwidth is modified, you will be billed based on the new billing mode. |
- The yearly/monthly and pay-per-use billing modes in Table 1 define how an EIP is billed, not how the FlexusX instance is billed.
Yearly/Monthly EIPs can only be billed by bandwidth, but pay-per-use EIPs can be billed by bandwidth, traffic, or shared bandwidth.
- When you purchase a yearly/monthly FlexusX instance, if you select Traffic or Shared bandwidth for Billed By, the EIP is billed on a pay-per-use basis. In this case, use the rules for modifying the bandwidth of a pay-per-use EIP.
- You can only modify bandwidth for FlexusX instances with EIPs bound.
- If a yearly/monthly EIP is bound to a FlexusX instance:
- Only the bandwidth name and bandwidth size can be changed. A yearly/monthly EIP can only be billed by bandwidth.
- The bandwidth size can be increased in the current subscription period, and decreased for the renewal period.
- Only the bandwidths of pay-per-use EIPs billed by bandwidth or traffic can be modified in batches. The bandwidths of yearly/monthly EIPs or pay-per-use EIPs billed by shared bandwidth cannot be modified in batches.
- Log in to the FlexusX console. In the upper left corner, click
and select a region. - Locate the FlexusX instance you want to modify the bandwidth for. Modify the bandwidth in either of the following ways:
- In the Operation column of the FlexusX instance, choose More > Manage Network > Modify Bandwidth.
- If the EIP bound to the FlexusX instance is billed by bandwidth or traffic, select the instance, and on the top of the list, choose More > Modify Bandwidth. You can use this method to batch modify bandwidth for instances.
- Follow the instructions to modify the bandwidth.
- Confirm the new configuration, select I acknowledge the price change and agree to proceed, and click Submit. Figure 1 Confirming the new configuration
- After the modification is complete, you can view the details on the EIPs tab of the FlexusX instance details page. Figure 2 Viewing the bandwidth information
