Updated on 2025-06-30 GMT+08:00
FlexusRDS Operations Supported by CTS
With Cloud Trace Service (CTS), you can record operations associated with FlexusRDS instances for later query, audit, and backtrack operations.
Table 1 FlexusRDS operations that can be recorded by CTS
Operation
Resource Type
Trace Name
Creating a DB instance or restoring data to a new instance
instance
createInstance
Enabling autoscaling
instance
instanceAction
Rebooting a DB instance
instance
instanceRestart
Restoring data to the original DB instance
instance
instanceRestore
Renaming a DB instance
instance
instanceRename
Resetting a password
instance
resetPassword
Setting database version parameters
instance
setDBParameters
Binding or unbinding an EIP
instance
setOrResetPublicIP
Adding a tag
instance
createTag
Deleting a tag
instance
deleteTag
Editing a tag
instance
modifyTag
Deleting a DB instance
instance
deleteInstance
Downloading a backup (using OBS)
backup
downLoadSnapshot
Downloading a backup (using a browser)
backup
backupsDownLoad
Deleting a backup
backup
deleteManualSnapshot
Deleting a frozen DB instance
all
rdsUnsubscribeInstance
Freezing a DB instance
all
rdsfreezeInstance
Renewing a DB instance
all
bssUpdateMetadata
