Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus RDS/ User Guide/ Working with FlexusRDS for PostgreSQL/ Monitoring/ Viewing Monitoring Metrics of a FlexusRDS for PostgreSQL Instance
Updated on 2025-06-30 GMT+08:00
This section describes how to view monitoring metrics of FlexusRDS for PostgreSQL instances and configure alarm rules. You can customize objects to be monitored and notification policies so that you can closely monitor your instances.
Viewing Metrics
  1. In the instance list, click the target instance name.
  2. Click the Monitoring tab and view the monitoring metrics of the instance.
    Figure 1 Metrics
    Table 1 Supported metrics
    Name
    Value Range
    Monitored Object
    Monitoring Interval (Raw Data)
    Inactive Logical Replication Slots
    Number of inactive logical replication slots
    ≥ 0
    1 minute
    CPU Usage
    CPU usage of the monitored object
    0-100%
    1 minute
    Temporary Files per Minute
    Number of temporary files generated within 1 minute
    ≥ 0 Count/min
    1 minute
    Memory Usage
    Memory usage of the monitored object
    0-100%
    1 minute
    Temporary File Size per Minute
    Size of temporary files generated within 1 minute
    ≥ 0 Byte/min
    1 minute
    IOPS
    Average number of I/O requests processed by the system in a specified period
    ≥ 0 counts/s
    1 minute
    Synchronous Replication Blocking Time
    Time during which synchronous replication between the primary and standby nodes is blocked
    ≥ 0s
    1 minute
    Network Input Throughput
    Incoming traffic in bytes per second
    ≥ 0 bytes/s
    1 minute
    Stream Replication Status of Standby Instance or Read Replica
    Stream replication status of the standby instance or a read replica. The value 0 indicates abnormal stream replication. A 1 indicates normal stream replication. A 2 means that this node is the primary instance.
    Count
    1 minute
    Network Output Throughput
    Outgoing traffic in bytes per second
    ≥ 0 bytes/s
    1 minute
    Inodes
    Used data disk inodes
    ≥ 0 counts
    5 minutes
    Storage Space Usage
    Storage usage of the monitored object
    0-100%
    1 minute
    Transaction Logs Usage
    Storage space usage of transaction logs
    ≥ 0 MB
    1 minute
    Replication Slot Usage
    Storage space usage of replication slot files
    ≥ 0 MB
    1 minute
    Database Connections in Use
    Number of database connections in use
    ≥ 0 counts
    1 minute
    Maximum Used Transaction IDs
    Maximum number of transaction IDs that have been used
    ≥ 0 counts
    1 minute
    Transaction Logs Generation
    Size of transaction logs generated per second
    ≥ 0 MB/s
    1 minute
    Oldest Replication Slot Lag
    Lagging size of the most lagging replica in terms of WAL data received
    ≥ 0 MB
    1 minute
    Replication Lag
    Replication lag delay
    ≥ 0 ms
    1 minute
    Connections in Use
    Number of connections in use (excluding built-in connections used for monitoring and O&M)
    ≥ 0 Counts
    1 minute
    Active Connections of Users
    Number of active connections used by users (excluding built-in active connections used for monitoring and O&M)
    ≥ 0 counts
    1 minute
    TPS
    Average execution times of submitted and rollback transactions per second
    ≥ 0 counts/s
    1 minute
    Connection Usage
    Percent of used PostgreSQL connections to the total number of connections
    0-100%
    1 minute
    Active Connections
    Number of active connections to a DB instance
    ≥ 0
    1 minute
    Idle Transaction Connections
    Number of connections with idle transactions
    ≥ 0
    1 minute
    Operation Rows
    Number of rows that are being inserted, deleted, updated, or queried
    ≥ 0
    1 minute
    Oldest Active Transaction Duration
    Length of time since the start of the transaction that has been active longer than any other current transaction
    ≥ 0 ms
    1 minute
    Oldest Two-Phase Commit Transaction Duration
    Length of time since the start of the transaction that has been prepared for two-phase commit longer than any other current transaction
    ≥ 0 ms
    1 minute
    Disk I/O Usage
    I/O usage of disks The disk I/O usage is the percentage of the time that the disk processes I/O requests to the total time.
    If the disk I/O usage reaches 100%, data is being written to the disk during the statistical period. The disk performance is determined by multiple metrics, such as IOPS, disk throughput, and read/write latency.
    0-100%
    1 minute
    Sessions Waiting for Locks
    Number of sessions that are waiting for locks
    ≥ 0
    1 minute
    Swap-In Rate
    Volume of data written from the swap partition to the memory per second
    ≥ 0 KB/s
    1 minute
    Swap-Out Rate
    Volume of data written from the memory to the swap partition per second
    ≥ 0 KB/s
    1 minute
    Total Swap Size
    Total size of the swap partition
    ≥ 0 MB
    1 minute
    Swap Usage
    Usage of the swap partition
    0-100%
    1 minute
    Maximum Database Age
    Maximum age of the current database, which is the value of max(age(datfrozenxid)) in the pg_database table
    ≥ 0
    1 minute
    User-mode CPU Time Percentage
    Percentage of time that the CPU is in user mode
    0-100%
    1 minute
    Kernel-mode CPU Time Percentage
    Percentage of time that the CPU is in kernel mode
    0-100%
    1 minute
    Disk I/O Wait Time Percentage
    Percentage of time that the CPU is waiting for disk I/O operations to complete
    0-100%
    1 minute
    Read I/O Latency
    Average latency (in milliseconds) of disks responding to read requests
    ≥ 0 ms
    1 minute
    Write I/O Latency
    Average latency (in milliseconds) of disks responding to write requests
    ≥ 0 ms
    1 minute
    Read IOPS
    Average number of read I/O requests processed by the system in a specified period
    ≥ 0 counts/s
    1 minute
    Write IOPS
    Average number of write I/O requests processed by the system in a specified period
    ≥ 0 counts/s
    1 minute
    Number of SQL Statements Executed for More Than 1s
    Number of slow SQL statements whose execution time is longer than 1s
    ≥ 0
    1 minute
    Number of SQL Statements Executed for More Than 3s
    Number of slow SQL statements whose execution time is longer than 3s
    ≥ 0
    1 minute
    Number of SQL Statements Executed for More Than 5s
    Number of slow SQL statements whose execution time is longer than 5s
    ≥ 0
    1 minute
    Number of SQL Statements Executed for More Than log_min_duration_statement
    Number of slow SQL statements whose execution time is longer than the value of log_min_duration_statement. You can change the value of this metric as required.
    ≥ 0
    1 minute
    WAL Size
    Size of WAL logs
    ≥ 0 GB
    5 minutes
    Audit Log Size
    Size of audit logs
    ≥ 0 GB
    5 minutes
    Memory Hit Rate
    Memory hit rate
    ≥ 0%
    1 minute
    Transactions Alive for More Than 1s
    The number of long-running transactions that are kept alive for more than 1s
    ≥ 0
    1 minute
    Transactions Alive for More Than 3s
    The number of long-running transactions that are kept alive for more than 3s
    ≥ 0
    1 minute
    Transactions Alive for More Than 5s
    The number of long-running transactions that are kept alive for more than 5s
    ≥ 0
    1 minute
    Transactions Idle for More Than 1s
    The number of long-running transactions that have been idle for more than 1s
    ≥ 0
    1 minute
    Transactions Idle for More Than 3s
    The number of long-running transactions that have been idle for more than 3s
    ≥ 0
    1 minute
    Transactions Idle for More Than 5s
    The number of long-running transactions that have been idle for more than 5s
    ≥ 0
    1 minute
    Two-Phase Transactions Running for More Than 1s
    The number of long-running transactions that have been running for more than 1s in two phases
    ≥ 0
    1 minute
    Two-Phase Transactions Running for More Than 3s
    The number of long-running transactions that have been running for more than 3s in two phases
    ≥ 0
    1 minute
    Two-Phase Transactions Running for More Than 5s
    The number of long-running transactions that have been running for more than 5s in two phases
    ≥ 0
    1 minute
Configuring Alarm Rules
  1. On the metric card, click + to go to the page for configuring alarm rules.
    Figure 2 Selecting a metric
  2. On the Create Alarm Rule page, configure required parameters.
    • Name: The system generates a random name for the alarm rule. You can change it as needed.
    • Description: Add supplementary information about the rule.
    • Alarm Policy: Policy for triggering an alarm. An alarm is triggered when the metric configured for this alarm reaches the preset threshold in consecutive periods.
    • Alarm Notification: Specify whether to notify users when alarms are triggered. Notifications can be sent by email, text message, or HTTP/HTTPS message.
      For details about how to configure alarm notification, see Creating an Alarm Rule in Cloud Eye User Guide.
  3. Click Create.
