- Product Bulletin
- Getting Started
User Guide
Working with FlexusRDS for MySQL
- Using IAM to Grant Access to FlexusRDS
- Buying a FlexusRDS for MySQL Instance
- Connecting to a FlexusRDS for MySQL Instance
- Suggestions on Using FlexusRDS for MySQL
- Data Migration
Instance Management
- Upgrading the Minor Version of a FlexusRDS for MySQL Instance
- Upgrading a FlexusRDS for MySQL Instance to an RDS DB Instance
- Changing the Name of a FlexusRDS for MySQL Instance
- Rebooting FlexusRDS for MySQL Instances
- Resetting the Administrator Password of a FlexusRDS for MySQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for MySQL Instance
- Binding an EIP to a FlexusRDS for MySQL Instance or Unbinding an EIP from a FlexusRDS for MySQL Instance
- Changing the VPC and Subnet of a FlexusRDS for MySQL Instance
- Renewing FlexusRDS for MySQL Instances
- Unsubscribing from a FlexusRDS for MySQL Instance
- Backups and Restorations
- Parameters
- Monitoring
- Logs
- Interconnection with CTS
- FlexusRDS for MySQL Tags
- FlexusRDS for MySQL Quotas
Working with FlexusRDS for PostgreSQL
- Permissions Management
- Buying a FlexusRDS for PostgreSQL Instance
- Connecting to a FlexusRDS for PostgreSQL Instance
- Suggestions on Using FlexusRDS for PostgreSQL
- Data Migration
Instance Management
- Changing the Name of a FlexusRDS for PostgreSQL Instance
- Rebooting FlexusRDS for PostgreSQL Instances
- Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance
- Binding an EIP to a FlexusRDS for PostgreSQL Instance or Unbinding an EIP from a FlexusRDS for PostgreSQL Instance
- Renewing FlexusRDS for PostgreSQL Instances
- Unsubscribing from a FlexusRDS for PostgreSQL Instance
- Creating a Manual Backup for a FlexusRDS for PostgreSQL Instance
- Deleting a Manual Backup of a FlexusRDS for PostgreSQL Instance
- Downloading a Full Backup of a FlexusRDS for PostgreSQL Instance
- Checking and Exporting Backup Information of a FlexusRDS for PostgreSQL Instance
- Restoring a FlexusRDS for PostgreSQL Instance
- Parameters
- Monitoring Management
- Logs
- FlexusRDS for PostgreSQL Tags
- FlexusRDS for PostgreSQL Quotas
- API Reference
- What Is FlexusRDS?
- Can FlexusRDS for MySQL and RDS for MySQL Instances Access Each Other?
- Can I Change the Instance Class of My FlexusRDS Instance?
- Does FlexusRDS Support Cross-AZ HA?
- What Is the Backup Policy of FlexusRDS?
- How Are FlexusRDS Backups Billed?
- How Do I Download FlexusRDS Backups to Restore Data Locally?
- Why Does the Root User of My FlexusRDS for MySQL Instance Not Have Super Permissions?
- Which Storage Engine Does FlexusRDS for MySQL Provide?
- Why Does FlexusRDS for MySQL Not Support the MyISAM Storage Engine?
- Does FlexusRDS for MySQL Support Read Replicas?
- Why Can't I Ping the EIP After It Is Bound to My FlexusRDS for MySQL Instance?
- How Do I Create Accounts and Databases for My FlexusRDS Instance?
- What Major Versions and Minor Versions Does FlexusRDS for MySQL Support?
- Why Are Pay-per-Use Instances Not Provided by FlexusRDS?
- Can I Scale Up the Storage Space of My FlexusRDS for MySQL Instance?
Suggestions on Parameter Tuning for a FlexusRDS for PostgreSQL Instance
Parameters are key configuration items in a database system. Improper parameter settings may adversely affect database performance. This section describes some important parameters for your reference. For details, visit the PostgreSQL official website.
For details on how to modify FlexusRDS for PostgreSQL parameters on the console, see Modifying Parameters of a FlexusRDS for PostgreSQL Instance.
Sensitive Parameters
The following parameters can result in system security and stability issues if set improperly:
- The search_path parameter must be set to a schema sequence where schemas are separated by commas (,). Ensure that the schemas exist. Otherwise, the database performance will be affected.
- If you enable the parameter log_duration, SQL statements containing sensitive information may be recorded in logs. You are advised to disable this parameter.
- log_min_duration_statement specifies how many milliseconds a query has to run before it has to be logged. The unit is millisecond. Setting this parameter to 0 means that all statements are recorded. Setting this parameter to -1 means that no statement is recorded. For details, see Viewing and Downloading Slow Query Logs of a FlexusRDS for PostgreSQL Instance.
- The temp_file_limit parameter limits the total size (in KB) of all temporary files when writing temporary files to the disk is triggered in a session. The value ranges from -1 to 2,147,483,647. The value -1 indicates that the total size of the temporary files is not limited.
- This parameter is only available for PostgreSQL 12, 13, 14, and 15.
- To prevent temporary files from occupying too much disk space and causing service exceptions, do not set this parameter to -1.
- If the parameter value is changed to a larger value for temporary use but is not changed to the original value after the use, the disk space will be continuously used to store temporary files. If the disk space is used up, services will be interrupted and the DB instance will become unavailable.
- The max_pred_locks_per_transaction and max_locks_per_transaction parameters need to be set based on the values of max_connections and max_prepared_transactions. Too large values may cause instance unavailability.
Performance Parameters
The following parameters can affect database performance:
- If log_statement is set to ddl, mod, or all, the operations for creating and deleting database users (including passwords and other sensitive information) are recorded. This operation affects database performance. Exercise caution when setting this parameter.
- Enabling the following parameters will affect the database performance: log_hostname, log_duration, log_connections, and log_disconnections. Exercise caution when enabling these parameters.
- The shared_buffers parameter is recommended to be a value ranging from 25% to 40% of the system memory. The maximum value of this parameter cannot exceed 80% of the system memory to avoid affecting database performance.
- The max_worker_processes parameter should be set based on the values of max_parallel_workers and max_parallel_workers_per_gather. If the max_worker_processes value is too large, the database performance will be affected.
