- Product Bulletin
- Getting Started
User Guide
Working with FlexusRDS for MySQL
- Using IAM to Grant Access to FlexusRDS
- Buying a FlexusRDS for MySQL Instance
- Connecting to a FlexusRDS for MySQL Instance
- Suggestions on Using FlexusRDS for MySQL
- Data Migration
Instance Management
- Upgrading the Minor Version of a FlexusRDS for MySQL Instance
- Upgrading a FlexusRDS for MySQL Instance to an RDS DB Instance
- Changing the Name of a FlexusRDS for MySQL Instance
- Rebooting FlexusRDS for MySQL Instances
- Resetting the Administrator Password of a FlexusRDS for MySQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for MySQL Instance
- Binding an EIP to a FlexusRDS for MySQL Instance or Unbinding an EIP from a FlexusRDS for MySQL Instance
- Changing the VPC and Subnet of a FlexusRDS for MySQL Instance
- Renewing FlexusRDS for MySQL Instances
- Unsubscribing from a FlexusRDS for MySQL Instance
- Backups and Restorations
- Parameters
- Monitoring
- Logs
- Interconnection with CTS
- FlexusRDS for MySQL Tags
- FlexusRDS for MySQL Quotas
Working with FlexusRDS for PostgreSQL
- Permissions Management
- Buying a FlexusRDS for PostgreSQL Instance
- Connecting to a FlexusRDS for PostgreSQL Instance
- Suggestions on Using FlexusRDS for PostgreSQL
- Data Migration
Instance Management
- Changing the Name of a FlexusRDS for PostgreSQL Instance
- Rebooting FlexusRDS for PostgreSQL Instances
- Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance
- Binding an EIP to a FlexusRDS for PostgreSQL Instance or Unbinding an EIP from a FlexusRDS for PostgreSQL Instance
- Renewing FlexusRDS for PostgreSQL Instances
- Unsubscribing from a FlexusRDS for PostgreSQL Instance
- Creating a Manual Backup for a FlexusRDS for PostgreSQL Instance
- Deleting a Manual Backup of a FlexusRDS for PostgreSQL Instance
- Downloading a Full Backup of a FlexusRDS for PostgreSQL Instance
- Checking and Exporting Backup Information of a FlexusRDS for PostgreSQL Instance
- Restoring a FlexusRDS for PostgreSQL Instance
- Parameters
- Monitoring Management
- Logs
- FlexusRDS for PostgreSQL Tags
- FlexusRDS for PostgreSQL Quotas
- API Reference
- What Is FlexusRDS?
- Can FlexusRDS for MySQL and RDS for MySQL Instances Access Each Other?
- Can I Change the Instance Class of My FlexusRDS Instance?
- Does FlexusRDS Support Cross-AZ HA?
- What Is the Backup Policy of FlexusRDS?
- How Are FlexusRDS Backups Billed?
- How Do I Download FlexusRDS Backups to Restore Data Locally?
- Why Does the Root User of My FlexusRDS for MySQL Instance Not Have Super Permissions?
- Which Storage Engine Does FlexusRDS for MySQL Provide?
- Why Does FlexusRDS for MySQL Not Support the MyISAM Storage Engine?
- Does FlexusRDS for MySQL Support Read Replicas?
- Why Can't I Ping the EIP After It Is Bound to My FlexusRDS for MySQL Instance?
- How Do I Create Accounts and Databases for My FlexusRDS Instance?
- What Major Versions and Minor Versions Does FlexusRDS for MySQL Support?
- Why Are Pay-per-Use Instances Not Provided by FlexusRDS?
- Can I Scale Up the Storage Space of My FlexusRDS for MySQL Instance?
Show all
Restoring a FlexusRDS for PostgreSQL Instance to a Point in Time
You can use automated backups to restore an instance to a specific point in time.
When you enter the time point that you want to restore the DB instance to, FlexusRDS downloads the most recent full backup file from OBS to the DB instance. Then, incremental backups are also restored to the specified point in time on the DB instance. Data is restored at an average speed of 40 MB/s.
- Do not run the reset master command on instances within their lifecycle. Otherwise, an exception may occur during the point-in-time recovery (PITR).
- Constraints on restoring data to a new DB instance:
- You can restore data to a new instance only when your account balance is greater than or equal to $0 USD. You will pay for the new instance specifications.
- The storage space of the new instance should be no less than that of the original instance.
- When you restore data to a new DB instance, large transactions in the original DB instance backup may cause a restoration failure. If the restoration fails, contact customer service.
- In the instance list, click the target instance name.
- Click Backups and Restorations.
- Click Restore above the backup list.
- Select the restoration date and time range, enter a time point within the selected time range, and select a restoration method. Then, click OK.
- Create New Instance
The Create New Instance page is displayed.
- The DB engine version of the new instance is the same as that of the original instance.
- You can select a new instance class for the new instance, but the storage of the new instance must be no less than that of the original instance.
- For details about the configuration items on the purchase page, see Buying a FlexusRDS for PostgreSQL Instance.
To change the instance class, choose a new one for the new instance on the Create New Instance page.
- View the restoration result. The result depends on which restoration method was selected:
