Help Center/
Huawei Cloud Flexus_Huawei Cloud Flexus RDS/
User Guide/
Working with FlexusRDS for PostgreSQL/
Instance Management/
Renewing FlexusRDS for PostgreSQL Instances
Updated on 2025-01-26 GMT+08:00
You can renew one or multiple yearly/monthly DB instances at a time.
- In the instance list, select the target DB instance and click Renew above the instance list.
You can also click the target instance name to go to the Overview page to renew the instance.
- In the displayed dialog box, confirm the instance to be renewed.
Figure 1 Renewing an instance
- Click OK to go to the renewal page and renew the instance.
Parent topic: Instance Management
