Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus RDS/ User Guide/ Working with FlexusRDS for PostgreSQL/ Instance Management/ Binding an EIP to a FlexusRDS for PostgreSQL Instance or Unbinding an EIP from a FlexusRDS for PostgreSQL Instance
Updated on 2025-09-26 GMT+08:00
You can bind an EIP to a DB instance for public accessibility, and you can unbind the EIP from the DB instance later if needed.
Precautions
  • You can buy an EIP on the network console and bind it to a FlexusRDS for PostgreSQL instance. One EIP can be bound to only one instance. For pricing details, see Elastic IP pricing details.
  • If a DB instance has already been bound with an EIP, you must unbind the EIP from the instance first before binding a new EIP to it.
Binding an EIP to a DB Instance
  1. In the instance list, click the target instance name to go to the Overview page.
  2. On the displayed Overview page, click Bind under the EIP field.
  3. In the displayed dialog box, all available EIPs are listed. Select the required EIP and click Yes.
  4. View the EIP that has been bound to the DB instance.
Unbinding an EIP from a DB Instance
  2. On the displayed Overview page, click Unbind under the EIP field.
  3. In the displayed dialog box, click Yes.
