Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus RDS/ User Guide/ Working with FlexusRDS for PostgreSQL/ Instance Management/ Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance
Updated on 2025-06-30 GMT+08:00
With storage autoscaling enabled, when FlexusRDS for PostgreSQL detects that you are running out of database space, it automatically scales up your storage.
  • If your account balance is insufficient, storage autoscaling will fail.
  • The storage space can be autoscaled up only when your instance status is Available or Storage full.
  • For a primary/standby DB instance, autoscaling the storage for the primary node will also autoscale the storage for the standby node.
  • If a yearly/monthly DB instance has pending orders, it will not be autoscaled.
  1. In the instance list, click the target instance name to go to the Overview page.
  2. On the Overview page, click Configure under the Configure Autoscaling field.
  3. In the displayed dialog box, click and configure the required parameters.
    Figure 1 Configuring autoscaling
    Table 1 Parameter description
    Enable Autoscaling
    If you select this option, autoscaling is enabled.
    Trigger If Available Storage Drops To
    If the available storage drops to a specified threshold (10%, 15%, or 20%), autoscaling is triggered.
    Increment
    Autoscaling increment, as a percentage. The default value range is from 5% to 50%.
    Autoscaling Limit
    The value range is from 120 to 4000, in GB. The limit must be no less than the storage of the DB instance.
  4. Click OK.
