Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance
You can reset the administrator password only through a primary instance. The new password is applied immediately without rebooting the instance.
If you forget the password of the administrator account root, you can reset the password.
Precautions
- If the password you provide is regarded as a weak password by the system, you will be prompted to enter a stronger password.
- If you change the administrator password of a primary instance, the administrator password of the standby instance will also be changed.
- The time required for the new password to take effect depends on the amount of service data currently being processed by the primary DB instance.
- To protect against brute force hacking attempts and ensure system security, change your password periodically.
- In the instance list, locate the target instance and click Reset Password in the Operation column.
- In the displayed dialog box, enter a new password and confirm the password. Figure 1 Resetting a password
Keep this password secure. The system cannot retrieve it.
The password must consist of 8 to 32 characters and contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters (~ ! @ # $ % ^ * - _ = + ? ,). Enter a strong password and periodically change it for security reasons.
- To submit the new password, click OK.
- To cancel the reset operation, click Cancel.
