Changing the Name of a FlexusRDS for PostgreSQL Instance
You can change the name of a DB instance as required.
- In the instance list, locate the instance that you want to edit name for and click
next to the instance name. Then, change the name and click OK.
Alternatively, click the target instance name. On the displayed page, click
under the DB Instance Name field and change the instance name.The instance name must start with a letter and consist of 4 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.) are allowed.
- To submit the change, click
. - To cancel the change, click
- Check the result in the instance list.
