Updated on 2025-09-26 GMT+08:00
Migrating Databases to FlexusRDS for PostgreSQL Using DRS
You can migrate data from RDS for PostgreSQL, self-managed PostgreSQL databases, PostgreSQL databases built on other clouds, self-managed Oracle databases, RDS for MySQL, self-managed MySQL databases, or MySQL databases built on other clouds to FlexusRDS for PostgreSQL, or from one FlexusRDS for PostgreSQL instance to another FlexusRDS for PostgreSQL instance.
You are advised to use Data Replication Service (DRS) to migrate data because it is easy to use and can complete a migration task in minutes. It facilitates data transfer between databases, helping you reduce DBA labor costs and hardware costs.
DRS Migration Solutions
The method for migrating databases to FlexusRDS for PostgreSQL using DRS is the same as that for migrating databases to RDS for PostgreSQL. For details, see Migration Solution Overview.
DRS Migration Billing
  • Real-time migration supports only the pay-per-use billing mode.
    Real-time migration tasks are free of configuration and data transmission fees in the first seven days, lowering your costs for migrating data to the cloud.
  • Real-time synchronization and DR support pay-per-use and yearly/monthly billing modes.
    Real-time migration and synchronization will provide long-term discounts, lowering your costs for data transfers.
For more information, see Data Replication Service Billing.
