- Product Bulletin
- Getting Started
User Guide
Working with FlexusRDS for MySQL
- Using IAM to Grant Access to FlexusRDS
- Buying a FlexusRDS for MySQL Instance
- Connecting to a FlexusRDS for MySQL Instance
- Suggestions on Using FlexusRDS for MySQL
- Data Migration
Instance Management
- Upgrading the Minor Version of a FlexusRDS for MySQL Instance
- Upgrading a FlexusRDS for MySQL Instance to an RDS DB Instance
- Changing the Name of a FlexusRDS for MySQL Instance
- Rebooting FlexusRDS for MySQL Instances
- Resetting the Administrator Password of a FlexusRDS for MySQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for MySQL Instance
- Binding an EIP to a FlexusRDS for MySQL Instance or Unbinding an EIP from a FlexusRDS for MySQL Instance
- Changing the VPC and Subnet of a FlexusRDS for MySQL Instance
- Renewing FlexusRDS for MySQL Instances
- Unsubscribing from a FlexusRDS for MySQL Instance
- Backups and Restorations
- Parameters
- Monitoring
- Logs
- Interconnection with CTS
- FlexusRDS for MySQL Tags
- FlexusRDS for MySQL Quotas
Working with FlexusRDS for PostgreSQL
- Permissions Management
- Buying a FlexusRDS for PostgreSQL Instance
- Connecting to a FlexusRDS for PostgreSQL Instance
- Suggestions on Using FlexusRDS for PostgreSQL
- Data Migration
Instance Management
- Changing the Name of a FlexusRDS for PostgreSQL Instance
- Rebooting FlexusRDS for PostgreSQL Instances
- Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance
- Binding an EIP to a FlexusRDS for PostgreSQL Instance or Unbinding an EIP from a FlexusRDS for PostgreSQL Instance
- Renewing FlexusRDS for PostgreSQL Instances
- Unsubscribing from a FlexusRDS for PostgreSQL Instance
- Creating a Manual Backup for a FlexusRDS for PostgreSQL Instance
- Deleting a Manual Backup of a FlexusRDS for PostgreSQL Instance
- Downloading a Full Backup of a FlexusRDS for PostgreSQL Instance
- Checking and Exporting Backup Information of a FlexusRDS for PostgreSQL Instance
- Restoring a FlexusRDS for PostgreSQL Instance
- Parameters
- Monitoring Management
- Logs
- FlexusRDS for PostgreSQL Tags
- FlexusRDS for PostgreSQL Quotas
- API Reference
- What Is FlexusRDS?
- Can FlexusRDS for MySQL and RDS for MySQL Instances Access Each Other?
- Can I Change the Instance Class of My FlexusRDS Instance?
- Does FlexusRDS Support Cross-AZ HA?
- What Is the Backup Policy of FlexusRDS?
- How Are FlexusRDS Backups Billed?
- How Do I Download FlexusRDS Backups to Restore Data Locally?
- Why Does the Root User of My FlexusRDS for MySQL Instance Not Have Super Permissions?
- Which Storage Engine Does FlexusRDS for MySQL Provide?
- Why Does FlexusRDS for MySQL Not Support the MyISAM Storage Engine?
- Does FlexusRDS for MySQL Support Read Replicas?
- Why Can't I Ping the EIP After It Is Bound to My FlexusRDS for MySQL Instance?
- How Do I Create Accounts and Databases for My FlexusRDS Instance?
- What Major Versions and Minor Versions Does FlexusRDS for MySQL Support?
- Why Are Pay-per-Use Instances Not Provided by FlexusRDS?
- Can I Scale Up the Storage Space of My FlexusRDS for MySQL Instance?
Using DAS to Connect to a FlexusRDS for PostgreSQL Instance (Recommended)
Data Admin Service (DAS) enables you to connect to and manage DB instances with ease on a web-based console. The permission required for connecting to DB instances through DAS has been enabled for you by default. Using DAS to connect to your DB instance is recommended, which is more secure and convenient.
- In the instance list, locate the target DB instance and click Log In in the Operation column.
Figure 1 Logging in to an instance
Alternatively, click the instance name in the instance list. On the displayed page, click Log In in the upper right corner.
- On the displayed login page, enter the username and password and click Log In.
