- Product Bulletin
- Getting Started
User Guide
Working with FlexusRDS for MySQL
- Using IAM to Grant Access to FlexusRDS
- Buying a FlexusRDS for MySQL Instance
- Connecting to a FlexusRDS for MySQL Instance
- Suggestions on Using FlexusRDS for MySQL
- Data Migration
Instance Management
- Upgrading the Minor Version of a FlexusRDS for MySQL Instance
- Upgrading a FlexusRDS for MySQL Instance to an RDS DB Instance
- Changing the Name of a FlexusRDS for MySQL Instance
- Rebooting FlexusRDS for MySQL Instances
- Resetting the Administrator Password of a FlexusRDS for MySQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for MySQL Instance
- Binding an EIP to a FlexusRDS for MySQL Instance or Unbinding an EIP from a FlexusRDS for MySQL Instance
- Changing the VPC and Subnet of a FlexusRDS for MySQL Instance
- Renewing FlexusRDS for MySQL Instances
- Unsubscribing from a FlexusRDS for MySQL Instance
- Backups and Restorations
- Parameters
- Monitoring
- Logs
- Interconnection with CTS
- FlexusRDS for MySQL Tags
- FlexusRDS for MySQL Quotas
Working with FlexusRDS for PostgreSQL
- Permissions Management
- Buying a FlexusRDS for PostgreSQL Instance
- Connecting to a FlexusRDS for PostgreSQL Instance
- Suggestions on Using FlexusRDS for PostgreSQL
- Data Migration
Instance Management
- Changing the Name of a FlexusRDS for PostgreSQL Instance
- Rebooting FlexusRDS for PostgreSQL Instances
- Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance
- Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance
- Binding an EIP to a FlexusRDS for PostgreSQL Instance or Unbinding an EIP from a FlexusRDS for PostgreSQL Instance
- Renewing FlexusRDS for PostgreSQL Instances
- Unsubscribing from a FlexusRDS for PostgreSQL Instance
- Creating a Manual Backup for a FlexusRDS for PostgreSQL Instance
- Deleting a Manual Backup of a FlexusRDS for PostgreSQL Instance
- Downloading a Full Backup of a FlexusRDS for PostgreSQL Instance
- Checking and Exporting Backup Information of a FlexusRDS for PostgreSQL Instance
- Restoring a FlexusRDS for PostgreSQL Instance
- Parameters
- Monitoring Management
- Logs
- FlexusRDS for PostgreSQL Tags
- FlexusRDS for PostgreSQL Quotas
- API Reference
- What Is FlexusRDS?
- Can FlexusRDS for MySQL and RDS for MySQL Instances Access Each Other?
- Can I Change the Instance Class of My FlexusRDS Instance?
- Does FlexusRDS Support Cross-AZ HA?
- What Is the Backup Policy of FlexusRDS?
- How Are FlexusRDS Backups Billed?
- How Do I Download FlexusRDS Backups to Restore Data Locally?
- Why Does the Root User of My FlexusRDS for MySQL Instance Not Have Super Permissions?
- Which Storage Engine Does FlexusRDS for MySQL Provide?
- Why Does FlexusRDS for MySQL Not Support the MyISAM Storage Engine?
- Does FlexusRDS for MySQL Support Read Replicas?
- Why Can't I Ping the EIP After It Is Bound to My FlexusRDS for MySQL Instance?
- How Do I Create Accounts and Databases for My FlexusRDS Instance?
- What Major Versions and Minor Versions Does FlexusRDS for MySQL Support?
- Why Are Pay-per-Use Instances Not Provided by FlexusRDS?
- Can I Scale Up the Storage Space of My FlexusRDS for MySQL Instance?
On this page
Show all
Help Center/
Huawei Cloud Flexus_Huawei Cloud Flexus RDS/
User Guide/
Working with FlexusRDS for PostgreSQL/
Permissions Management/
FlexusRDS Custom Policies
Custom policies can be created to supplement the system policies of FlexusRDS.
You can create custom policies in either of the following two ways:
- Visual editor: Select cloud services, actions, resources, and request conditions without the need to know policy syntax.
- JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following contains examples of common FlexusRDS custom policies.
Example Custom Policies
Example: Allowing users to create manual backups
{ "Version": "1.1", "Statement": [{ "Effect": "Allow", "Action": ["rds:backup:create"] }] }
Parent topic: Permissions Management
