Easily Switch Between Product Types
You can click the drop-down list box to switch between different product types.
- Getting Started
User Guide
- Granting Permissions to Use FlexusL Instances Through IAM
- Purchasing a FlexusL Instance
- Remotely Logging In to a FlexusL Instance
- Managing FlexusL Instances
- Managing Images
- Managing EVS Disks
- Managing Server Security
- Managing Backups
- Managing Domain Names
- Monitoring
Best Practices
- Best Practices for FlexusL
Setting Up a Website
- Managing Servers Using the BT Panel
- Building a WordPress Website
- Using Matomo to Build a Website Traffic Statistics System
- Using Odoo to Build an ERP System
- Using Moodle to Build an Online Learning System
- Using Joomla to Build a Content Management System
- Using Ghost to Build a Personal Blog
- Using EspoCRM to Build a Content Management System
- Setting Up the Development Environment
- Setting Up an Application
- Server Migration
- API Reference
Product Consulting
- What Are the Differences Among FlexusL, FlexusX, and ECS?
- How Do I Find My Purchased FlexusL Instances on the Management Console?
- Where Can I View the FlexusL Instance ID and Cloud Server ID Packaged in the FlexusL Instance?
- Can I Migrate Cloud Servers to FlexusL?
- What Should I Do If I Do Not Have Permissions to Purchase FlexusL?
- What Regions Does FlexusL Support?
- What Is the Relationship Among FlexusL Instances, the Dashboard, and the O&M Page?
- Billing
- Creation and Unsubscription
- Specification Changes
OS and Image
- Do FlexusL OS Images Provide Visualized Dashboards?
- What Should I Do If a Private Image Cannot Be Used to Create a FlexusL Instance or Change the OS of a FlexusL Instance Because the Password Reset Plug-in Is Not Installed on the Image or the Image's onekey_resetpasswd Tag Is Missing?
- How Do I Check that an Application Image Has Been Up and Running?
- How Do I View the Applications That Are Installed in the FlexusL Application Images by Default?
- Why Can't I Open the Dashboard of the Application Pre-installed in the Application Image?
- How Do I Upgrade the BT Panel?
- Why Can't I Access the Dashboard of the Application Pre-installed in the Application Image After Entering the Initial Username and Password?
- What Do I Do If HSS Is Not Started After I Use a Private Image to Create a FlexusL Instance or Change the OS of an Instance?
- Remote Login
Password
- What Are the Username and Password for Remotely Logging In to a FlexusL Instance Server?
- What Can I Do If I Forget the Login Password of a FlexusL Instance?
- What Should I Do If the Password Cannot Be Reset After I Use a Private Linux Image to Create a FlexusL Instance or Change the OS of an Existing FlexusL Instance and I Forgot the Initial Password of the Private Image?
- What Should I Do If the Password Cannot Be Reset After I Use a Private Linux Image to Create a FlexusL Instance or Change the OS of an Existing FlexusL Instance and I Know the Initial Password of the Private Image?
Network
- Does a FlexusL Instance Have an EIP?
- Can I Change the Public and Private IP Addresses of a FlexusL Instance?
- How Do I Use Data Packages in FlexusL Instances?
- How Do I View the Traffic Usage of My FlexusL Instance?
- Can I Add a Data Package to a FlexusL Instance?
- What Do I Do If My FlexusL Instance Freezes?
- How Does FlexusL Instances Communicate with Each Other and with Other Cloud Resources Over a Private Network?
EVS Disks
- How Do I Detach or Unsubscribe from a System or Data Disk of a FlexusL Instance?
- Can I Use EVS Disk Snapshots to Back Up FlexusL Instance Data?
- Can EVS Disks of FlexusL Instances Be Expanded?
- Can I Change the EVS Disk Type for a FlexusL Instance?
- Can I Attach Existing Data Disks to My FlexusL Instances?
Product Consulting
On this page
Show all
Help Center/
Huawei Cloud Flexus_Huawei Cloud Flexus L Instance/
User Guide/
Managing FlexusL Instances/
Viewing Information About a FlexusL Instance
