- Getting Started
User Guide
- Granting Permissions to Use FlexusL Instances Through IAM
- Purchasing a FlexusL Instance
- Remotely Logging In to a FlexusL Instance
- Managing FlexusL Instances
- Managing Images
- Managing EVS Disks
- Managing Server Security
- Managing Backups
- Managing Domain Names
- Monitoring
Best Practices
- Best Practices for FlexusL
Setting Up a Website
- Managing Servers Using the BT Panel
- Building a WordPress Website
- Using Matomo to Build a Website Traffic Statistics System
- Using Odoo to Build an ERP System
- Using Moodle to Build an Online Learning System
- Using Joomla to Build a Content Management System
- Using Ghost to Build a Personal Blog
- Using EspoCRM to Build a Content Management System
- Setting Up the Development Environment
- Setting Up an Application
- Server Migration
- API Reference
Product Consulting
- What Are the Differences Among FlexusL, FlexusX, and ECS?
- How Do I Find My Purchased FlexusL Instances on the Management Console?
- Where Can I View the FlexusL Instance ID and Cloud Server ID Packaged in the FlexusL Instance?
- Can I Migrate Cloud Servers to FlexusL?
- What Should I Do If I Do Not Have Permissions to Purchase FlexusL?
- What Regions Does FlexusL Support?
- What Is the Relationship Among FlexusL Instances, the Dashboard, and the O&M Page?
- Billing
- Creation and Unsubscription
- Specification Changes
OS and Image
- Do FlexusL OS Images Provide Visualized Dashboards?
- What Should I Do If a Private Image Cannot Be Used to Create a FlexusL Instance or Change the OS of a FlexusL Instance Because the Password Reset Plug-in Is Not Installed on the Image or the Image's onekey_resetpasswd Tag Is Missing?
- How Do I Check that an Application Image Has Been Up and Running?
- How Do I View the Applications That Are Installed in the FlexusL Application Images by Default?
- Why Can't I Open the Dashboard of the Application Pre-installed in the Application Image?
- How Do I Upgrade the BT Panel?
- Why Can't I Access the Dashboard of the Application Pre-installed in the Application Image After Entering the Initial Username and Password?
- What Do I Do If HSS Is Not Started After I Use a Private Image to Create a FlexusL Instance or Change the OS of an Instance?
- Remote Login
Password
- What Are the Username and Password for Remotely Logging In to a FlexusL Instance Server?
- What Can I Do If I Forget the Login Password of a FlexusL Instance?
- What Should I Do If the Password Cannot Be Reset After I Use a Private Linux Image to Create a FlexusL Instance or Change the OS of an Existing FlexusL Instance and I Forgot the Initial Password of the Private Image?
- What Should I Do If the Password Cannot Be Reset After I Use a Private Linux Image to Create a FlexusL Instance or Change the OS of an Existing FlexusL Instance and I Know the Initial Password of the Private Image?
Network
- Does a FlexusL Instance Have an EIP?
- Can I Change the Public and Private IP Addresses of a FlexusL Instance?
- How Do I Use Data Packages in FlexusL Instances?
- How Do I View the Traffic Usage of My FlexusL Instance?
- Can I Add a Data Package to a FlexusL Instance?
- What Do I Do If My FlexusL Instance Freezes?
- How Does FlexusL Instances Communicate with Each Other and with Other Cloud Resources Over a Private Network?
EVS Disks
- How Do I Detach or Unsubscribe from a System or Data Disk of a FlexusL Instance?
- Can I Use EVS Disk Snapshots to Back Up FlexusL Instance Data?
- Can EVS Disks of FlexusL Instances Be Expanded?
- Can I Change the EVS Disk Type for a FlexusL Instance?
- Can I Attach Existing Data Disks to My FlexusL Instances?
Product Consulting
Show all
Expanding the Backup Vault Associated with a FlexusL Instance
Ensure that the capacity of the vault associated with the FlexusL instance is sufficient, or the backup will fail. You can expand the vault capacity as needed. This section describes how to expand the vault capacity on the FlexusL console. For details about how to expand the vault capacity on the CBR console, see Expanding Vault Capacity.
- The vault capacity can only be expanded. It cannot be reduced.
- The disk can only be expanded when the server is Running or Stopped.
Billing
The expanded capacity is billed.
- Log in to the FlexusL console and click a resource card to go to the instance details page.
- Choose Cloud Backup Vaults and click Expand Capacity.
- On the displayed page, enter a new capacity.
The vault capacity must be at least as big as the server capacity you want to back up. If the vault capacity is smaller than the total capacity to be backed up, the backup task will fail. For example, if your system disk and data disks use 80 GiB, the vault capacity must be greater than 80 GiB. Otherwise, the backup will fail.
- Click Buy Now and complete the payment as prompted.
After the purchase, check whether the vault capacity has increased on the console.
