Enabling or Disabling a Container Service
If you do not need to use a container service temporarily, you can disable it. After a container service is disabled, the containers for running the container service will not exist, and you cannot manage resources on the containers.
It takes 3 to 5 minutes to disable a container service. Do not run your application during this period of time.
Disabling a Container Service.
- Log in to the FlexusCCI console.
- Locate the container service you want to disable and click Disable in the Operation column. Wait until the container service is disabled. After the container service is disabling, the containers will not exist.Figure 1 Disabling a container service
Enabling a Container Service
- Locate the container service you want to enable and click Enable in the Operation column. Wait until the container service is enabled. After the container service is enabled, the billing continues.Figure 2 Enabling a container service
