On this page
Show all
Help Center/
Huawei Cloud Flexus_Huawei Cloud Flexus Container Instance/
User Guide/
Accessing a FlexusCCI Container over a Public Network
Before using the public network to access a FlexusCCI container, you need to specify the public network setting for the container.
After a container service is created, if the listening port of the application is mapped to a port on the public network, the application can be accessed using an EIP.
- Log in to the FlexusCCI console.
- Locate the container service, view and copy public network access address in the Public Network Details.
- Paste the public network access address in the address box of a browser and access the application.
