Help Center/ DataArts Fabric/ User Guide/ DataArts Fabric SQL/ Managing SQL Sessions/ Checking SQL Execution Status
Updated on 2025-12-19 GMT+08:00
- Log in to the DataArts Fabric Workspace Management Console. On the displayed page, locate your desired workspace card and click Access Workspace.
- In the navigation pane on the left, choose Development and Production > SQL Session.
- On the displayed page, locate the session for which you wish to check SQL status and click SQL Execution Status in its Operation column. Here, you can check the query statement, status, and submission time.
- (Optional) On the displayed page, locate the session you want to cancel SQL execution and click Cancel Execution in its Operation column. In the Cancel Execution dialog box that appears, enter YES and click OK.
Parent topic: Managing SQL Sessions
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
