Setting an Alarm Rule
You can set alarm rules for EVS to customize the monitoring scope and notification policies and stay aware of the EVS disk statuses.
An alarm rule includes the alarm rule name, monitoring scope, monitoring metrics, alarm thresholds, monitoring interval, and whether to send notifications. This section describes how to set alarm rules.
- Sign in to the console.
- Click
in the upper left corner and select your region and project. - Choose Management & Governance > Cloud Eye.
- In the navigation pane on the left, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule to create one, or modify an existing alarm rule.
The following describes how you can modify an existing alarm rule:
- Click the name of the target alarm rule.
- Click Modify in the upper right corner of the page.
- On the Modify Alarm Rule page, set parameters as required.
- Click OK.
After the alarm rule is modified, you will be notified when an alarm is triggered.
