Checking EVS Snapshot Details
You can check the snapshot details, including the region and AZ, source disk information, and tags.
Checking Snapshot Details
- Sign in to the EVS console.
- Click
in the upper left corner and select a region. - In the navigation pane on the left, choose Elastic Volume Service > Snapshots.
The Snapshots page is displayed.
- In the snapshot list, view the snapshot name, status, creation time, and disk name.
- (Optional) View more snapshot details.
- Standard snapshots: In the snapshot list, locate the target snapshot and click its name. On the Basic Information page, view more details about the snapshot.
- Legacy snapshots: Select a snapshot and click it in the lower part of the console to view its details. Figure 1 Viewing a legacy snapshot
Snapshot Statuses
| Snapshot Status | Description | Allowed Operation |
| Creating | The snapshot is being created. | None |
| Available | The snapshot is successfully created. |
| Deleting | The snapshot is being deleted. | None |
| Error | An error occurs when you try to create a snapshot. | Deleting snapshots |
| Deletion failed | An error occurs when you try to delete a snapshot. | Deleting snapshots |
| Rolling back | The snapshot is being used to roll back data. NOTE:
| None |
| Backing up | This status only shows up for temporary snapshots. When you create a backup for an EVS disk, a temporary snapshot is automatically created. This status indicates that a temporary snapshot is being created during the backup creation. NOTE: Temporary snapshots are created through the CBR service. Do not perform any operation on these snapshots. | None |
Helpful Links
- For more snapshot FAQs, see Snapshot.
- To check the snapshot space usage, see Checking the EVS Snapshot Storage Usage (for Standard Snapshots).
