Updated on 2025-05-29 GMT+08:00
Tag Overview
Tags identify EVS resources for purposes of easy categorization and quick search.
If your organization has enabled the tag policy type for EVS and has a tag policy attached, you must comply with the tag policy rules when creating disks, otherwise disks may fail to be created. Contact the organization administrator to learn more about tag policies.
Table 1 Tag overview
Operation
Adding a Tag
Add tags for existing disks or during disk creations.
Modifying a Tag
Change tag values for existing disks. Tag keys of existing disks cannot be changed.
Deleting a Tag
Delete tags that are no longer needed for existing disks.
Searching for Disks by Tag
After tags are added, search for disks by tags.
