Attaching an Existing Non-Shared Disk
Updated on 2024-12-26 GMT+08:00
This section describes how to attach an existing non-shared disk to a server to be used as a data disk. A non-shared disk can be attached to one server only.
You can view the disk information in the disk list. A disk can be attached to a server to be used as a data disk when all of the following conditions are met:
  • Disk Sharing: Disabled
  • Function: Bootable disk or Data disk
  • Status: Available
  • Bootable disks are the system disks detached from servers. A bootable disk can be re-attached to a server to be used as a system disk or data disk depending on the disk function selected.
  • Non-shared disks purchased together with or later added to a yearly/monthly ECS cannot be attached to other ECSs, because the disks are associated with the original ECS.
Notes and Constraints
  • Cloud servers created from ISO images are only used for OS installation. They have limited functions and cannot have EVS disks attached.
  • A non-shared disk can be attached to one server only.
  • The disk and server must be in the same region and AZ.
  • A detached, non-shared yearly/monthly data disk purchased together with a server can only be re-attached to the original server to be used as a data disk.
  • A server must be in the Running or Stopped state before disks can be attached to it.
  • A frozen disk cannot be attached.
  • A detached system disk purchased together with a yearly/monthly server can be re-attached to be used as a data disk for any server. If you want to use it again as a system disk, you must attach it to the original server.
  • A detached system disk purchasedcreated together with a pay-per-use server can be re-attached to be used as a data disk for any server. If you want to use it again as a system disk, you must attach it to a server that uses the same image as the original server.
  1. Log in to the console.
  2. Click in the upper left corner and choose Storage > Elastic Volume Service.
    The Elastic Volume Service page is displayed.
  3. In the disk list, locate the disk and click Attach.
  4. Select a server to attach the disk. Ensure that the disk and server are in the same AZ. After you select the server, the system automatically inputs Data disk as the disk function.
    One device name can be used for one disk only. For how to obtain the disk name in the OS, see FAQ "How Do I Obtain My Disk Name in the ECS OS Using the Device Identifier Provided on the Console?" in the Elastic Cloud Server FAQs.
    Figure 1 Attach Disk
  5. Click OK to go back to the disk list page.
    The status of the disk is Attaching, indicating that the disk is being attached to the server. When the disk status changes to In-use, the disk has been attached.
  6. (Optional) Mount the existing disk partition on a mount point if you are attaching the disk to a Linux server. The mount command is as follows:
    mount Disk partition Mount point
Helpful Links
To find out why your disk cannot be attached, see Why Can't I Attach My Disk to a Server?
To check out more attachment FAQs, see Attachment.
