Help Center/ Elastic Volume Service/ User Guide/ Managing EVS Recycle Bin/ Recovering Disks from the Recycle Bin
Updated on 2026-05-11 GMT+08:00
During routine data management, you may accidentally delete important disk data, resulting in data loss. If the recycle bin is enabled, deleted disks are moved to the recycle bin. You can recover any disk within the retention period to prevent data loss.
  • If your account is frozen or restricted, disks in the recycle bin cannot be recovered.
  • If the ECS recycle bin is enabled, EVS disks deleted together with ECSs will be retained in the recycle bin for the same period of time as the ECSs and can only be recovered on the ECS side.
Billing
Disks in the recycle bin are all billed on a pay-per-use basis, regardless of their billing modes before deletion. Pay-per-use billing applies after disks are recovered from the recycle bin.
If you demand yearly/monthly billing for a recovered disk, attach it to an ECS or a BMS, and then change the server's billing mode to yearly/monthly.
To learn how to change pay-per-use billing to yearly/monthly, see From Pay-per-Use to Yearly/Monthly.
  1. Sign in to the EVS console.
  2. Click the Recycle Bin tab.
  3. On the Recycle Bin tab page, locate the disk you want to recover and click Recover in the Operation column.
    The Recover Disk page is displayed.
  4. Click Submit.
    • If the recovery succeeds, the disk will be displayed in the disk list, and the disk status is Available.
    • If the recovery fails, the disk remains in the recycle bin, and the disk status changes to Recovery failed.
